Contributor I
GRE Tunnel between Master & Guest controller
Hi All,
I want to create tunnel between my master controllers in VRRP mode which also enabled with PEF licenses and Guest controller in DMZ. I hope i should create tunnel using my Virtual IP address. Can anyone tell me the commands to create a tunnel between these for guest users and how to verify the tunnel status..?
Re: GRE Tunnel between Master & Guest controller
VRRP addresses cannot be tunnel endpoints.
See here:
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/VRRP-IP-cannot-be-L2-GRE-tunnel-endpoint/td-p/33572
Tim Cappalli | Aruba Security
MVP
I've actually have had this up and running in a lab where both source and destination where VRRP address on both sides.
configure terminal
	interface tunnel 1
        description "to edge"
        tunnel source 192.168.253.1
        tunnel mode gre 0
        tunnel destination 11.11.11.1
        trusted
        mtu 1400
        tunnel vlan 252
		no shutdown
configure terminal
	interface tunnel 1
        description "to main"
        tunnel source 11.11.11.1
        tunnel mode gre 0
        tunnel destination 192.168.253.1
        trusted
        mtu 1400
        tunnel vlan 252
Koen (ACMX #351 | ACDX #547 | ACCP)
Contributor I
Thanks ... I need to create L3 GRE since they are in serperate vlans.
MVP
Not sure what you mean here, but if you want to 'extend' the guest valn from controller 1 to mcontroller 2 you do not need an L3 gre tunnel.
If the guest vlan is different on both end you do but why would you require this? The vlan is only important at the central site since you're transporting all traffic there anyway right?
