Frequent Contributor II
GRE tunnel is not coming up from Local controller to DMZ
Hi All,
I am configuring a GRE tunnel from Local controller ot DMZ controller, it is reachble and able to ping each other.
After configuring GRE tunnel I can see that "ENCAPS" is going high in DMZ side and "DECAPS" is going high in Local controller side.
But encaps in local controller is not increasing and decaps in DMZ controller is not increasing.
Local controller config:
interface tunnel 100
tunnel source "local mgmt  ip"
tunnel destination " dmz mgmt ip"
tunnel mode gre 1
tunnel keepalive
trusted
tunnel vlan "l2 vlan"
DMZ controlle config:
tunnel source " dmz mgmt ip"
tunnel destination " local mgmt ip"
tunnel mode gre 1
tunnel keepalive
trusted
rana
Re: GRE tunnel is not coming up from Local controller to DMZ
Try turning off keepalives.
tried , no luck.
Stil the tunnel is down.
rana
