Frequent Contributor I
Going from 6.3.1.5 to 6.4.2.2
i was just planning an upgrade to be able to use the AP-205's.  However i noticed the 6.4 firmwares were not yet in the general availability directory, but in the early deployment?
Am i compromising stability if i install the early deployment?
Re: Going from 6.3.1.5 to 6.4.2.2
I have quite a few large customers (including hospitals) running 6.4.2.2 without issue.
It will be GA shortly.
Tim Cappalli | Aruba Security
Frequent Contributor II
Does 6.4.2.2 support mesh with the AC access points?
Mesh is not currently support on 802.11ac access points.
About one week after the upgrade...  No problems detected so far...
