Graphs for Packet type distribution
Need help in AirWave PLEASE - - is it possible to get the following statistics in AirWave or in a Report? 1. 802.11 Packet Type Distribution 2. Packet Size Distribution If from the Controller's GUI and select an AP, I can get something like this .... (pls see attached) But the pie chart is per AP, per SSID and per radio. I'm more interested if the pie chart can get me what is the total packet type distribution for an AP for a radio (no matter how many VAPs are configured there in one physical AP). Any idea how can I achieve it? Thank you. Regards Kenneth
Re: Graphs for Packet type distribution
Unfortunately, that is information that is only in the controller, not Airwave AFAIK.
If you tell us what you are trying to achieve, maybe there is another way to get that information.
Thanks Colin.
Ok, understand the info is only in the controller.
Quick question: there is only 1 physical AP and hence 1 physical 5 GHz radio and 1 physical 2.4 GHz radio. In the controller, why the graphs for packet size and packet type distribution is per SSID?  If there are 3 VAPs configured, how do I do the Maths?  (I mean, check the graph in each SSID and then add them all up?)
I'm interested in airtime efficiency. I understand there are some 802.11 control frames that are only sent using OFDM rates. I might be wrong, but I believe control frames are usually very small packet sizes (<64 bytes).  In very high-density 802.11ac network, I want to know how many of those small sizes and slow rate packets are consuming my airtime.  When more airtime is being wasted on these packets, it dramatically dimishes the Effective Data Rates for the payload.
Kind regards
Kenneth
Honestly, those graphs have not changed for quite a few years.  Those graphs are  good for information, but we found that with increasing density interference, RF utilization and dropping broadcasts plays a much larger part in performance than packet efficiency.  Back in the day, manufacturers did not write drivers to improve performance; today they do, so effiiency does not play a large part in wireless performance.  On the Dashboard tab on the controller, things like RF utilization, noise and what band a user is on is a better indication of performance.
Trusted Contributor I
Kenneth,
Yes, control frames are sent at OFDM rates. 24Mbps seems to be most common data rate used.  Perhaps this correlates to the highest basic rate supported by the AP?
If you really want airtime stats you could collect them with a sniffer or AP remote capture and packet capturing software (Savvius Omnipeek is a good option).  Metageek makes software called Eye PA, which takes pcap files and graphs the packets into pie charts showing you the airtime that's utilized.  This will answer your question about airtime utilization..
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
