Leo
Guest Network Issue
We have 3 wireless networks (one for production and two for guests) on each AP. We have 3 master controllers and 225 local controllers on different sites. The traffic from production one is drop to local production network and the traffic from two guest wireless go through tunnel from local controller to master controller. And then through firewall all the way go outside to Internet. Only HTTP and HTTPS are allowed on guests. Guest WLANs are totally separated from production. Guest WLANs are using captive portal for user login. Recently one of 225 sites reported that guest wireless is not working. Users can login captive portal without problems. The Internet browsing sometimes works and sometimes not or very slow. Most of time not working. I have rebuilt local controller and set MTU to 1500bytes but no luck.The guests networks are using the same configuration and firewall rules on all 225 sites but only this site is not working properly. Does anyone have the same experience? What else I need to check on local controller or master controller. Thanks
Re: Guest Network Issue
you could try lowering the MTU to 1100
Leo
Thanks, I'll try that
Leo
I tried to put in MTU 1100 but still no luck.
Leo
Also I replaced the local controller with a brand new one with the same config but nothing changed.
Did you put the 1100 MTU in on both sides of the tunnel ?
Leo
Hi cjoseph,
I just changed "SAP MTU" in AP system profile to 1500 for this site. I am new, could you please show me where/how to find the MTU for tunnel? we are using Aruba OS 5.0.3.
thank you,
So the SAP MTU is the MTU for the access point.  Not there.
If you have a GRE tunnel it should be at the interface level of the tunnel:
interface tunnel 20
MTU 1100
Do that on both sides of the tunnel.
Leo
I'll try to change tunnel MTU in next our next change window. I'll let you know how things going. Thank you so much.
By the way,  what is the default MTU for interface tunnel on Aruba controller?
thanks,
Leo
Problem was solved by adding the VLAN for this site to truested group on master controller. thanks,
