Frequent Contributor I
Guest Provisioning (Captive Portal) Aruba Controller
Hi All,
I am going to configuring Guest Access from Controller. When i did and try to connect to the Guest SSID then the controller redirect to me the controller not to captive portal page. Default Role in L3 Authentication i make "guest", in AAA initial role i make "logon". Can any body tell me what i will do to fix this issue.
Re: Guest Provisioning (Captive Portal) Aruba Controller
Have you assigned the Captive Portal Profile to your Initial role in the AAA profile?
If you post the output of the below where XXXX is your initial (probably the logon role)
#show rights XXXX
(sent from a mobile device)
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Hi Zalion,
Attached is the output file you requested.
Following are the roles which i configured in AAA and L3 Authentication profile.
Initial Role in AAA profile = guest-logon
Default Role in L3 Authentication (Captive Portal) = guest
If you run the below, do you see the Captive Portal profile assigned?
show rights guest-logon
Here's an example of my inital role showing the Captive Portal profile being assinged (see the last line). It is using the default Captive Portal profie.
(Lab620) #show rights guest-logon
Valid = 'Yes'
CleanedUp = 'No'
Derived Role = 'guest-logon'
 Up BW:No Limit   Down BW:No Limit
 L2TP Pool = default-l2tp-pool
 PPTP Pool = default-pptp-pool
 Number of users referencing it = 0
 Periodic reauthentication: Disabled
 DPI Classification: Enabled
 Youtube education: Disabled
 Web Content Classification: Enabled
 ACL Number = 9/0
 Max Sessions = 65535
 Check CP Profile for Accounting = TRUE
 Captive Portal profile = default
