Guest Provisioning issue
Hi there,
We have an issue with guest provisioning on OS where we cannot edit existing accounts to extend access etc.
When I try to change the Account "End" field (where the account expiry date/time is set) and then click "Save" the session just hangs or nothing happens.
I have tried this across multiple browsers including IE7-9 and Chrome but same result. Are there any Javascript setting necessary for this to work?
The workaround is to setup the account from scratch which works fine.
Re: Guest Provisioning issue
Do you have this problem when logged in as an Admin or when you are logged in as  a guest provisioning user?
Colin Joseph
Aruba Customer Engineering
Hi Colin,
When logged on as a Guest Provisioning user. When I log in as an admin I get full console rather than GPP so don't know if this happens with this login
I am using ArubaOS anf firefox 8.0 and it works for me. Try opening a private browsing session and then try the same. It worked fine even with the java plugins disabled.
