Guest SSID not visible to all devices
  • 1.  Guest SSID not visible to all devices
    Posted Mar 21, 2012 05:04 AM
    I have problems creating a guest ssid that is visible to all devices.
    I have tried both manually and by wizard, but ssid is only visible to some laptops.
    For example the ssid is not visible to a HP and a Macbook air, but is visible to some Dell laptops.
    I have tried both radio profile all and locked to g band.
    Anyone have any idea...?
    Vegard
  • 2.  RE: Guest SSID not visible to all devices
    Posted Mar 21, 2012 07:23 AM
    Are you have the problem with only that wireless network not being seen?
  • 3.  RE: Guest SSID not visible to all devices
    Posted Mar 21, 2012 08:44 AM
    No, all the SSIDs on that controller act the same way..
    Vegard
  • 4.  RE: Guest SSID not visible to all devices
    Posted Mar 21, 2012 08:45 AM
    How long has this network been in production, and what regulatory domain is it?
  • 5.  RE: Guest SSID not visible to all devices
    Posted Mar 21, 2012 09:07 AM
    This is a new installation. First time setup.
    This controller is in Norway...
    Vegard
  • 6.  RE: Guest SSID not visible to all devices
    Posted Mar 21, 2012 09:11 AM
    Do you have access to the command line of the controller? If you do, type "show ap bss-table" to see what networks are being broadcasted from each access point..
  • 7.  RE: Guest SSID not visible to all devices
    Posted Mar 21, 2012 09:23 AM
    bss                ess           s/p  ip            phy   type  ch/EIRP/max-EIRP  cur-cl  ap name     in-t(s)  tot-t         mtu   acl-state  acl  fm
    d8:c7:c8:0b:c5:80  office@skill  1/6  172.22.1.116  a-HT  ap    153-/24/24        1       skill-ap01  0        4h:59m:41s    1500  -          1    T
    d8:c7:c8:27:6e:00  office@skill  1/6  172.30.1.140  g-HT  ap    11/22.5/22.5      0       skill-ap12  0        19m:0s        1500  -          1    T
    d8:c7:c8:0b:c5:81  guest@skill   1/6  172.22.1.116  a-HT  ap    153-/24/24        0       skill-ap01  0        3h:2m:38s     1500  -          53   T
    d8:c7:c8:09:5a:f0  office@skill  1/6  172.22.1.138  a-HT  ap    161-/24/24        8       skill-ap02  0        1d:2h:19m:8s  1500  -          1    T
    d8:c7:c8:27:6a:b0  office@skill  1/6  172.30.1.139  g-HT  ap    1/22.5/22.5       0       skill-ap11  0        19m:1s        1500  -          1    T
    d8:c7:c8:09:5a:f1  guest@skill   1/6  172.22.1.138  a-HT  ap    161-/24/24        0       skill-ap02  0        3h:2m:38s     1500  -          53   T
    d8:c7:c8:27:6e:08  office@skill  1/6  172.30.1.140  a-HT  ap    40-/12/23         1       skill-ap12  0        19m:0s        1500  -          1    T
    d8:c7:c8:27:6e:09  guest@skill   1/6  172.30.1.140  a-HT  ap    40-/12/23         0       skill-ap12  0        18m:51s       1500  -          53   T
    d8:c7:c8:27:6a:b8  office@skill  1/6  172.30.1.139  a-HT  ap    36+/18/23         4       skill-ap11  0        19m:1s        1500  -          1    T
    d8:c7:c8:27:6a:b9  guest@skill   1/6  172.30.1.139  a-HT  ap    36+/18/23         0       skill-ap11  0        18m:51s       1500  -          53   T
    Looks right to me.. All SSIDs is visible on all APs..
    Vegard
  • 8.  RE: Guest SSID not visible to all devices
    Posted Mar 23, 2012 06:22 AM
    I figured out now the the problem only exists on the AP93s, not on the AP105.
    Also only a/n radio light is on, on the AP93.. a/b/g radio is off..
    Vegard
  • 9.  RE: Guest SSID not visible to all devices
    Posted Mar 24, 2012 01:39 PM
    When i do a:
    (skill-aruba01) #show ap active
    Active AP Table
    Name        Group    IP Address    11g Clients  11g Ch/EIRP/MaxEIRP  11a Clients  11a Ch/EIRP/MaxEIRP  AP Type  Flags  Uptime         Outer IP
    skill-ap02  Ostfold  172.22.1.138  0                                 0            AP:HT:153-/24/24     93              2d:6h:17m:29s  N/A
    skill-ap01  Ostfold  172.22.1.116  0                                 0            AP:HT:44+/23/23      93              2d:6h:17m:29s  N/A
    skill-ap11  Oslo     172.30.1.139  0            AP:HT:11/12/22.5     0            AP:HT:149+/24/24     105             3d:4h:38m:50s  N/A
    skill-ap12  Oslo     172.30.1.140  0            AP:HT:11/12/22.5     0            AP:HT:161-/24/24     105             3d:4h:33m:47s  N/A
    It looks like the g-radio is not on, on the AP93s..
    Can this has anything do do with it?
    Vegard
  • 10.  RE: Guest SSID not visible to all devices
    Posted Mar 24, 2012 03:56 PM
    Yes.  That would be your problem.
  • 11.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 04:38 AM
    Do you know how to fix this?
    Vegard
  • 12.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:01 AM
    Go to configuration > wireless > ap configuration. Edit the Ostford ap group. Expand ap, then click on ap system profile. In the right pane there should be a parameter called " rf band". Change it to "g" then click on apply.
  • 13.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:11 AM
    I have checked that and it is already on g band..
  • 14.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:13 AM
    Are you using the built in rf planner on the controller?
  • 15.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:16 AM
    Yes, i have depoyed a RF plan, but the APs does not belong to that RF plan yet..
  • 16.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:21 AM
    Allright.  type this:
    show ap config ap-name <name of ap>  | include "RF Band"
    It should tell you where the AP is getting its "RF Band" configuration from.
  • 17.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:23 AM
    (skill-aruba01) #show ap config ap-name skill-ap01  | include "RF Band"
    RF Band                                                         g                               g                      ap system-profile "default"
    RF Band for AM mode scanning                                    all                             all                    ap system-profile "default"
    It is the default profile, and as the picture show that shows that it should use the g band.
  • 18.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:27 AM
    Is that Skill-Aruba01 AP on the RF plan on the controller?
  • 19.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:30 AM
    No..
  • 20.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:31 AM
    Under configuration > wireless > ap configuration, do you have any "AP specific" configurations?
  • 21.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:32 AM
    No, its blank..
  • 22.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:34 AM
    type "show ap debug driver-log ap-name <name of ap>"
  • 23.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:37 AM
    (skill-aruba01) #show ap debug driver-log ap-name skill-ap01
    Flash variant: 16M
    On node 0 totalpages: 16384
      DMA zone: 16384 pages, LIFO batch:3
      DMA32 zone: 0 pages, LIFO batch:0
      Normal zone: 0 pages, LIFO batch:0
      HighMem zone: 0 pages, LIFO batch:0
    Cache parity protection disabled
    Using 195.000 MHz high precision timer. cycles_per_jiffy=390000
    Memory: 58020k/65536k available (1849k kernel code, 7456k reserved, 682k data, 2936k init, 0k highmem)
    Calibrating delay loop... 259.07 BogoMIPS (lpj=259072)
     available.
    detected lzma initramfs
    initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=12298240
    LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ............................................................................................................................................................................................
    Returning IRQ 48
    AR7240 GPIOC major 0
    wdt: registered with refresh
    Enabling Watchdog
    Talisker RSSI LED initialization
    Creating 1 MTD partitions on "ar7240-nor0":
    0x00000000-0x01000000 : "flash"
    i2c /dev entries driver
    i2c-talisker: using default base 0x18040000
    lo: Disabled Privacy Extensions
    IPv6 over IPv4 tunneling driver
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    AG7240: Length per segment 1536
    AG7240: Max segments per packet 1
    AG7240: Max tx descriptor count    40
    AG7240: Max rx descriptor count    252
    AG7240: fifo cfg 3 01f00140
    AG7240CHH: Mac address for unit 0
    AG7240CHH: d8:c7:c8:c8:bc:58
    ATHRSF1_PHY: Port 0, Neg Success
    ATHRSF1_PHY: unit 0 phy addr 0 <6>AP xml model 43, num_radios 1 (jiffies 4182)
    init_asap_mod: installation:0
    radio 0: band 2 ant 0 max_ssid 16
    setting bond0 as bridge child
    setting gre0 as split child
    ag7240_ring_alloc Allocated 640 at 0x80401800
    ag7240_ring_alloc Allocated 4032 at 0x80452000
    Virian MDC CFG Value ==> 4
    Setting PHY...
    ATHRSF1_PHY: unit 0 phy addr 0 Not enabling interrupts in AR7242 yet...
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    Kernel watchdog refresh ended.
    AG7240: enet unit:0 is up...
    RGMii 100Mbps full duplex
    AG7240: done cfg2 0x7115 ifctl 0x10000 miictrl
    ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    wlan: 0.8.4.2 (Atheros/multi-bss)
    ath_hal: module license 'Proprietary' taints kernel.
    ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
    ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
    ath_rate_atheros: Aruba Networks Rate Control Algorithm
    ath_dfs: Version 2.0.0
    Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
    ath_spectrum: Version 2.0.0
    ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
    ath_pci: 0.9.4.5 (Atheros/multi-bss)
    PCI: Setting latency timer of device 0000:00:00.0 to 64
    wifi0: Base BSSID d8:c7:c8:0b:c5:80, 16 available BSSID(s)
    bond0 address=d8:c7:c8:c8:bc:58
    br0 address=d8:c7:c8:c8:bc:58
    wifi0: AP type AP-93, radio 0, max_bssids 16
    wifi0: Atheros 9280: mem=0x10000000, irq=48 hw_base=0xb0000000
    kat driver unloaded
    br0: no IPv6 routers present
    bond0: no IPv6 routers present
    vap_device_event: UTC Time:16:20:31  dev aruba000 (0:0) has been registered
    vap_device_event: dev aruba000 (0:0) is up
    vap aruba000 vlan is 731. not discovering tunnel vlan
    vap_device_event: UTC Time:16:20:32  dev aruba001 (0:1) has been registered
    vap_device_event: dev aruba001 (0:1) is up
    vap aruba001 vlan is 732. not discovering tunnel vlan
    wifi0: no IPv6 routers present
    vap_device_event: dev aruba001 (0:1) is going down
    vap_device_event: dev aruba001 (0:1) is down
    vap_device_event: UTC Time:20:25:20  dev aruba001 (0:1) has been unregistered
    Driver Log
    Current Log Level 3 Log Counter 81 Timestamp   267481.4404
  • 24.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:39 AM
    the "driver log" at the bottom is missing.  Can you try with another access point?
  • 25.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:43 AM
    Sure..
    (skill-aruba01) #show ap debug driver-log ap-name skill-ap02
    Flash variant: 16M
     available.
    Returning IRQ 48
    Enabling Watchdog
    AG7240CHH: d8:c7:c8:c8:95:af
    ag7240_ring_alloc Allocated 640 at 0x82dfe800
    ag7240_ring_alloc Allocated 4032 at 0x8044f000
    Setting PHY...
    wifi0: Base BSSID d8:c7:c8:09:5a:f0, 16 available BSSID(s)
    bond0 address=d8:c7:c8:c8:95:af
    br0 address=d8:c7:c8:c8:95:af
    kat driver unloaded
    vap_device_event: UTC Time:16:20:30  dev aruba000 (0:0) has been registered
    vap_device_event: UTC Time:16:20:31  dev aruba001 (0:1) has been registered
    Driver Log
    Current Log Level 3 Log Counter 76 Timestamp   267826.941719
    1           0.0      aruba000: Scheduling VAP CONFIG update
    2           0.217    aruba000: Encryption Mode Set to 40
    3           0.237    aruba000: WPS Mode Set to 0
    4           0.249    aruba000: HT Mode Set to 1
    5           0.249    aruba000: 40mhz enable to 1
    6           0.249    aruba000: 40mhz GI to 1
    7           0.249    aruba000: STBC TX streams to 1
    8           0.249    aruba000: STBC RX streams to 1
    9           0.249    aruba000: Beacon rate to 1000
    10          0.249    aruba000: A-MPDU: Enabled, Tx Max 65535 Rx Max 3 Min Spacing 6
    11          0.249    aruba000: Basic Rate Set to 150
    12          0.249    aruba000: Supported Rate Set to ff0
    13          0.249    aruba000: DTIM Period Set to 1
    14          0.249    aruba000: Preamble Set to Long
    15          0.249    aruba000: ESSID Set to office@skill
    16          0.249    aruba000: Max Retries Set to 8
    17          0.249    aruba000: RTS Threshold Set to 2333
    18          0.249    aruba000: Ageout Set to 1000
    19          0.249    aruba000: WMM ENABLED
    20          0.249    aruba000: VAP CONFIG DONE
    21          0.392418 wifi0: Country Code Set to US
    22          0.404472 wifi0: EIRP (Config: 0.-5dBm, Set: 18.0dBm, AP Max: 18.0dBm, Reg Max: 36dBm), Conducted Power Set: 18.0dBm, Gain: 0.0dBm
    23          0.404522 wifi0: Channel Set to 153 (mesh-mode: 0, state: 0)
    24          0.404547 wifi0: Internal Antenna Gain Set to 6.0 dB for 5 GHz
    25          0.404568 wifi0: Internal Antenna Selected
    26          0.404707 wifi0: EIRP (Config: 12.0dBm, Set: 12.0dBm, AP Max: 24.0dBm, Reg Max: 36dBm), Conducted Power Set: 6.0dBm, Gain: 6.0dBm
    27          0.404748 wifi0: enabling 40Mhz (channel 153-)
    28          0.404769 aruba000: enabling HT on  1/1
    29          0.404808 wifi0: RADIO CONFIG DONE
    30          0.411294 wifi0: Scheduling RADIO CONFIG update
    31          0.788312 wifi0: Country Code Set to US
    32          0.800163 wifi0: EIRP (Config: 12.0dBm, Set: 12.0dBm, AP Max: 24.0dBm, Reg Max: 36dBm), Conducted Power Set: 6.0dBm, Gain: 6.0dBm
    33          0.800214 wifi0: Channel Set to 153 (mesh-mode: 0, state: 5)
    34          0.800240 wifi0: Internal Antenna Gain Set to 6.0 dB for 5 GHz
    35          0.800268 wifi0: Internal Antenna Selected
    36          0.800290 wifi0: Antenna Mode Selected: AUTO
    37          0.800309 wifi0: enabling 40Mhz (channel 153-)
    38          0.800345 wifi0: RADIO CONFIG DONE
    39          0.815864 aruba001: Scheduling VAP CONFIG update
    40          0.815995 aruba001: Encryption Mode Set to 1
    41          0.816014 aruba001: WPS Mode Set to 0
    42          0.816035 aruba001: HT Mode Set to 1
    43          0.816053 aruba001: 40mhz enable to 1
    44          0.816071 aruba001: 40mhz GI to 1
    45          0.816088 aruba001: STBC TX streams to 1
    46          0.816107 aruba001: STBC RX streams to 1
    47          0.816125 aruba001: Beacon rate to 6000
    48          0.816151 aruba001: A-MPDU: Enabled, Tx Max 65535 Rx Max 3 Min Spacing 6
    49          0.816178 aruba001: enabling HT on  1/1
    50          0.816208 aruba001: Basic Rate Set to 150
    51          0.816227 aruba001: Supported Rate Set to ff0
    52          0.816249 aruba001: DTIM Period Set to 1
    53          0.816249 aruba001: Preamble Set to Long
    54          0.816249 aruba001: ESSID Set to guest@skill
    55          0.816249 aruba001: Max Retries Set to 8
    56          0.816249 aruba001: RTS Threshold Set to 2333
    57          0.816249 aruba001: Ageout Set to 1000
    58          0.816249 aruba001: WMM ENABLED
    59          0.816249 aruba001: VAP CONFIG DONE
    60        406.260955 wifi0: Scheduling RADIO CONFIG update
    61        406.261355 wifi0: EIRP (Config: 15.0dBm, Set: 15.0dBm, AP Max: 24.0dBm, Reg Max: 36dBm), Conducted Power Set: 9.0dBm, Gain: 6.0dBm
    62        406.261403 wifi0: enabling 40Mhz (channel 153-)
    63        406.261447 wifi0: RADIO CONFIG DONE
  • 26.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:45 AM
    Any reason why the regulatory domain for that AP is set to US?
  • 27.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:48 AM
    No, but i have tried to set it to Norwegian, and then all the SSIDs disapeared from the air..
    So it didnt help.. :)
  • 28.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:49 AM
    Type "show country trail"
  • 29.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:50 AM
    (skill-aruba01) # show country trail
    Thu Sep 29 17:32:02 2011: Switch configured for domain: CA
    Thu Sep 29 17:32:06 2011: Setting hardware to unrestricted domain
    2011-09-29_16-45-22: Upgrade: domain CA
  • 30.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:52 AM
    Last question:  What version of Code is this?
    type "show ap allowed-channels ap-name <name of ap>"
  • 31.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 09:54 AM
    The controller is running 6.1.3.0
    (skill-aruba01) #show ap allowed-channels ap-name skill-ap02
    Allowed Channels for AP "skill-ap02" Country Code "US" Country "United States"
    PHY Type                 Allowed Channels
    802.11g (indoor)         1 2 3 4 5 6 7 8 9 10 11
    802.11a (indoor)         36 40 44 48 149 153 157 161 165
    802.11g (outdoor)        1 2 3 4 5 6 7 8 9 10 11
    802.11a (outdoor)        149 153 157 161 165
    802.11g 40MHz (indoor)   1-5 2-6 3-7 4-8 5-9 6-10 7-11
    802.11a 40MHz (indoor)   36-40 44-48 149-153 157-161
    802.11g 40MHz (outdoor)  1-5 2-6 3-7 4-8 5-9 6-10 7-11
    802.11a 40MHz (outdoor)   149-153 157-161
    802.11a (DFS)
  • 32.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 10:02 AM
    What is the difference between the AP group Ostford and Oslo?  Please try to provsion one of the APs in the Ostford group to Oslo instead and see what happens.
  • 33.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 10:15 AM
    The difference is that office@skill i AP group Oslo has another vlan.
    I tried to "move" skill-ap01 into group Oslo, but that didnt change much..
    Active AP Table
    skill-ap02  Ostfold  172.22.1.138  0                                 0            AP:HT:153-/24/24     93              3d:2h:55m:27s  N/A
    skill-ap01  Oslo     172.22.1.116  0                                 0            AP:HT:44+/23/23      93              3m:4s          N/A
    skill-ap11  Oslo     172.30.1.139  0            AP:HT:11/12/22.5     0            AP:HT:149+/24/24     105             4d:1h:16m:48s  N/A
    skill-ap12  Oslo     172.30.1.140  0            AP:HT:11/12/22.5     0            AP:HT:161-/24/24     105             4d:1h:11m:45s  N/A
    Flags: a = Reduce ARP packets in the air;  A = Enet1 in active/standby mode;
           B = Battery Boost On; C = Cellular; D = Disconn. Extra Calls On;
           d = Drop Mcast/Bcast On; E = Wired AP enabled; K = 802.11K Enabled; n = Don't convert IPv6 Mcast RA to Ucast
           L = Client Balancing Enabled; M = Mesh; N = 802.11b protection disabled;
           P = PPPOE; R = Remote AP; X = Maintenance Mode;
           1 = 802.1x authenticated AP; F = AP failed 802.1x authentication;2 = Using IKE version 2;
    Channel followed by "*" indicates channel selected due to unsupported configured channel.
    "Spectrum" followed by "^" indicates Local Spectrum Override in effect.
    Num APs:4
    The radio is still not active..
  • 34.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 10:25 AM
    Type "show log system 50"
  • 35.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 10:28 AM
    Mar 22 09:57:47 :303086:  <ERRS> |AP d8:c7:c8:ca:76:ab@172.30.1.139 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Mar 22 09:57:50 :303022:  <WARN> |AP d8:c7:c8:ca:76:e0@172.30.1.140 nanny|  Reboot Reason: No reboot message found.
    Mar 22 09:58:49 :303022:  <WARN> |AP skill-ap11@172.30.1.139 nanny|  Reboot Reason: AP rebooted Thu Mar 22 09:57:47 PST 2012; SAPD: Rebooting after provis                                    ioning
    Mar 22 09:59:16 :303086:  <ERRS> |AP d8:c7:c8:ca:76:e0@172.30.1.140 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Mar 22 10:00:18 :303022:  <WARN> |AP d8:c7:c8:ca:76:e0@172.30.1.140 nanny|  Reboot Reason: AP rebooted Thu Mar 22 09:59:16 PST 2012; SAPD: Reboot after su                                    ccessful image upgrade
    Mar 22 10:02:50 :303086:  <ERRS> |AP d8:c7:c8:ca:76:e0@172.30.1.140 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Mar 22 10:03:51 :303022:  <WARN> |AP skill-ap12@172.30.1.140 nanny|  Reboot Reason: AP rebooted Thu Mar 22 10:02:50 PST 2012; SAPD: Rebooting after provis                                    ioning
    Mar 23 08:15:45 :303086:  <ERRS> |AP skill-ap01@172.22.1.116 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Mar 23 08:15:45 :303086:  <ERRS> |AP skill-ap02@172.22.1.138 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Mar 23 08:16:29 :303022:  <WARN> |AP skill-ap01@172.22.1.116 nanny|  Reboot Reason: AP rebooted Fri Mar 23 08:15:45 PST 2012; SAPD: Rebooting after provis                                    ioning
    Mar 23 08:16:29 :303022:  <WARN> |AP skill-ap02@172.22.1.138 nanny|  Reboot Reason: AP rebooted Fri Mar 23 08:15:45 PST 2012; SAPD: Rebooting after provis                                    ioning
    Mar 23 08:19:23 :303086:  <ERRS> |AP skill-ap01@172.22.1.116 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Mar 23 08:19:23 :303086:  <ERRS> |AP skill-ap02@172.22.1.138 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Mar 23 08:20:05 :303022:  <WARN> |AP skill-ap02@172.22.1.138 nanny|  Reboot Reason: AP rebooted Fri Mar 23 08:19:23 PST 2012; SAPD: Rebooting after provis                                    ioning
    Mar 23 08:20:06 :303022:  <WARN> |AP skill-ap01@172.22.1.116 nanny|  Reboot Reason: AP rebooted Fri Mar 23 08:19:22 PST 2012; SAPD: Rebooting after provis                                    ioning
    Mar 26 11:11:46 :303086:  <ERRS> |AP skill-ap01@172.22.1.116 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Mar 26 11:12:29 :303022:  <WARN> |AP skill-ap01@172.22.1.116 nanny|  Reboot Reason: AP rebooted Mon Mar 26 11:11:46 PST 2012; SAPD: Rebooting after provis                                    ioning
    Mar 26 11:26:45 :303086:  <ERRS> |AP skill-ap01@172.22.1.116 nanny| Process Manager (nanny) shutting down - AP will reboot!
    Mar 26 11:26:46 :303086:  <ERRS> |AP skill-ap02@172.22.1.138 nanny| Process Manager (nanny) shutting down - AP will reboot!
  • 36.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 10:30 AM
    Are you physically near any of those access points?  Do you have a console cable?
  • 37.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 10:35 AM
    No, sorry, not right now. Iam at home and the APs at work in another town.
    I tried to create a new AP group called "sarpsborg" with reg. domain NO, and provision the APs to that AP group, but then i get this:
    Active AP Table
    skill-ap11  Oslo   172.30.1.139  0            AP:HT:11/12/22.5     0            AP:HT:149+/24/24     105             4d:1h:37m:29s  N/A
    skill-ap12  Oslo   172.30.1.140  0            AP:HT:11/12/22.5     0            AP:HT:161-/24/24     105             4d:1h:32m:26s  N/A
    Num APs:2
    (skill-aruba01) #show ap radio-database
    AP Radio Database
    Name        Group      AP Type  IP Address    Status            Flags  Switch IP      11g Mode/Chan/EIRP/Cli  11a Mode/Chan/EIRP/Cli
    skill-ap01  Sarpsborg  93       172.22.1.116  Up 3m:22s         I      172.16.102.20                          AP(HT)/44+/0/0
    skill-ap02  Sarpsborg  93       172.22.1.138  Up 3m:22s         I      172.16.102.20                          AP(HT)/120-/0/0
    skill-ap11  Oslo       105      172.30.1.139  Up 4d:1h:37m:32s         172.16.102.20  AP(HT)/11/12/0          AP(HT)/149+/24/0
    skill-ap12  Oslo       105      172.30.1.140  Up 4d:1h:32m:29s         172.16.102.20  AP(HT)/11/12/0          AP(HT)/161-/24/0
    Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
           I = Inactive; H = Using 802.11n license; D = Dirty or no config
           X = Maintenance Mode; P = PPPoE AP; B = Built-in AP
           R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP; c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
           M = Mesh node; Y = Mesh Recovery
    The APs in group "sarpsborg" becomes inactive..
    Do you know why this is?
  • 38.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 10:38 AM
    type "show ap database" to see if those APs have any flags.  Do you have any virtual APs in that ap-group Sarpsborg?
    This should work:
    (host) #show ap allowed-channels country-code NO ap-type ap-93
    Allowed Channels for AP Type ap-93 Country Code "NO" Country "Norway"
    802.11g (indoor)         1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (indoor)         36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
    802.11g (outdoor)        1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (outdoor)        36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
    802.11a 40MHz (indoor)   36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136
    802.11a 40MHz (outdoor)  36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136
    802.11a (DFS)            52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
    #AP124
  • 39.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 10:45 AM
    Yes, stupid me, i had not assigned any Virtual APs to it.
    Now they are not inactive anymore, but still the g radio doesnt show:
    AP Radio Database
    skill-ap01  Sarpsborg  93       172.22.1.116  Up 12m:42s               172.16.102.20                          AP(HT)/44+/23/0
    skill-ap02  Sarpsborg  93       172.22.1.138  Up 12m:42s               172.16.102.20                          AP(HT)/120-/15/0
    skill-ap11  Oslo       105      172.30.1.139  Up 4d:1h:46m:52s         172.16.102.20  AP(HT)/11/12/0          AP(HT)/149+/24/0
    skill-ap12  Oslo       105      172.30.1.140  Up 4d:1h:41m:49s         172.16.102.20  AP(HT)/11/12/0          AP(HT)/161-/24/0
    Total APs:4
  • 40.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 10:48 AM
    Please post the entire config of "show ap config ap-name <name of ap>"
  • 41.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 10:55 AM
    Its attached..
    Attachment(s)
    docx
    skill-ap02.docx   19 KB 1 version
  • 42.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 11:07 AM
    Thanks, for that.
    In the rf ARM profile default, you should disable power-save-aware scan.  Also disable client-aware scan, and multi-band scan.
    Theoretically those should not make a difference, but that is the only idea I have before opening a TAC case.
  • 43.  RE: Guest SSID not visible to all devices
    Posted Mar 25, 2012 11:34 AM
    Ok, as you said, that didnt make a difference. :)
    I will open a TAC case now..
    Thank you very much for your time!!
    I will post a solution when i get this figured out.. :)
  • 44.  RE: Guest SSID not visible to all devices
    Posted Mar 29, 2012 02:23 AM
    I have now solved the case with great help from TAC.
    This is the solution:
    apboot > purge
    apboot > clear os
    apboot > setenv serverip <Controller-IP>
    apboot >  save
    apboot > reset
    After that i reprov. the AP and then the G radio was up! :)
    Vegard
  • 45.  RE: Guest SSID not visible to all devices
    Posted Mar 29, 2012 06:37 AM
    I am glad they figured it out.  Can you please mark this solved?
    Thanks!
