Contributor I
Guest Users Provision/ Management on Aruba WLC 7010
Dear Team,
We are looking a solution for Guest wifi users management on Aruba 7010 controller.
Our requirements are mentioned below.
  1. Self-provisioning of users (once someone connected Guest SSID, web browser should automatically redirect to user registration portal once we submit some personal information like name, mobile number, etc need to automatically generate login username & password, over same web session or via SMS.)
  2. Able to set the expiry time for the automatically generated guest username & password (username & password validity, maximum internet usage duration)
  3. Captive portal login page customization (captive portal page logo, font, colour, etc)
  4. Authentication, Authorization & Accounting facility.
Regards
ASAMEDT
Contributor I
Re: Guest Users Provision/ Management on Aruba WLC 7010
I believe these can be done thru Clearpass Guest
