Guest Wireless Authentication Method.
Team,
We are looking at some open wireless authentication for guests. The SSID should be seen and on connecting to this SSID this should redirect to a page asking to accept some user policies.
On accepting this should directly give you the authentication and Internet only access. i.e. this should be a open SSID.
Any suggestions?
regards,
N.
Valued Contributor II
Re: Guest Wireless Authentication Method.
This can be achieved through Captive Portal authentication. do you use CPPM ? if yes, you can implement many more features in guest access such as, Sponsor approval, MAC caching , Self registration etc..
Please feel free if you need some more help on this.
Cheers,
Venu Puduchery,
