Regular Contributor I
Guest external DHCP and traffic routing
We currently have multiple controllers in different sites.  Each is providing DHCP for guest access via the local dhcp server on the controller.  We need to move the dhcp server to an external server because the internal has surpassed its purpose.
What are recommendations for this in regards to the DHCP server placement?  How will the guest vlan have access to this server in order to get an ip address?
Retired Employee
Re: Guest external DHCP and traffic routing
salvi,
You will have to configure the DHCP helper address "pointing to external DHCP server" under the guest VLAN interface.
(config) #interface vlan <guest-vlan>
(config-subif)#ip helper-address ?
<address> DHCP Server Address
HT
Yes, but we are using asubnets that are not being routed through our local network.  In order to have a centralized DHCP server it would have to be located in our Core Network, which is in a different site.  We want to keep guest users off our local LAN.
Retired Employee
In that case, you can setup L2 GRE tunnels between the controllers and tunnel the guest vlan.
On Local controller
interface tunnel <tunnel-id>
description "Tunnel Interface"
tunnel source local-controller-ip
tunnel mode gre 0
tunnel destination dest-controller-ip
tunnel vlan <guest-vlan>
HT
