Occasional Contributor I
Guest users from local controller not redirecting to captive portal
I have a setup usiing mater / local enviorment where guest user's traffic comes only into master controller and then redirect to captive portal (clearpass) for self register/logon process.
This works well for users on master controller, but not from local controllers. Users are getting DHCP and they can resolve DSN as well. But they failed to redirect to captive portal and times out when open a web browser.
DHCP server for guest is on master controler. GRE tunnel created to port guest traffic from local controller and spitting into guest VLAN.  GRE tunnel trusted on local side and untrusted at master side.
config extract as below
Local Controllre
interface tunnel 101
description "Tunnel Interface"
tunnel source loopback
tunnel mode gre 0
tunnel destination 10.99.40.99
trusted
mtu 1500
tunnel vlan 32
Master Controller
tunnel mode gre 0
tunnel destination 10.99.30.99
mtu 1500
tunnel vlan 32
Thanks inadvance
Aruba
Re: Guest users from local controller not redirecting to captive portal
Does the local controller have an IP on the client VLAN? It is required for captive portal redirects.
AMFX | ACCX | ACDX | ACMX
Thanks heaps,  adding IP address to client vlan on local controller solve the issue.
Since client vlan on local bridged to client vlan on master via L2 GRE tunnel, I didn't see any requirement for IP address on local side.
Cheers
