cdj
Contributor I
HA AP Fast Failover Issue
I'm having trouble configuring the ha-fast failover feature.
I have two 7220s running 6.4.2.4FIPS with VRRP & centralized licensing configured.
If someone can please look at my configuration below and see what's wrong:(note: not real ip addresses)
master ip address: 10.1.1.1
standby-master ip address: 10.1.1.2
VRRP ip address: 10.1.1.3
Master controller ha failover config:
Ha group-profile AP-Failover
controller 10.1.1.1 role dual
controller 10.1.1.2 role dual
state-sync
pre-shared-key password
exit
Ha group-membership AP-Failover
Standby-Master controller ha failover config:
Thanks.
Re: HA AP Fast Failover Issue
Did you assigned the master IP address under the ap system profile > LMS-IP ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
cdj
Contributor I
No, I have the VIP configured as lms-ip under the ap system profile
It should be pointing to the active controller not the VIP
The vrrp is to build the master redundancy not the AP redundancy that's why you adde the ip addresses of each controller in the group
Thank you
Victor Fabian
