4me
Contributor I
HA fast failover configuration giude
Valued Contributor II
Re: HA fast failover configuration giude
HI,
Here is your gude for deploying HA model.
Active/Active Deployment model
In this model, two controllers are deployed in dual mode. Controller one acts as standby for the APs served by controller two, and vice-versa. Each controller in this deployment model supports approximately 50% of its total AP capacity, so if one controllerfails, all the APs served by that controller would fail over to the other controller , thereby providing high availability redundancy to all APs in the cluster.
Figure 1  Active-Active HA Deployment
Click to view a larger size.
1:1 Active/Standby Deployment model
In this model, the active controller supports up to 100% of its rated capacity of APs, while the other controller in standby mode is idle. If the active controller fails, all APs served by the active controller would failover to the standby controller.
Figure 2  1:1 Active/Standby Deployment
N:1 Active/Standby Deployment model
In this model, the active controller supports up to 100% of its rated AP capacity, while the other controller is idle in standby mode. If an active controller fails, all APs served by the active controller would failover to the standby controller. This model requires that the AP capacity of the standby controller is able to support the total number of APs distributed across all active controllers in the cluster.
In the cluster shown in the example below, the standby controller has enough AP capacity to support the total number of APs terminating at the active controllers. ( Controller 1 and Controller 2)
Figure 3  1:1 Active/Standby Deployment
AP Communication with Controllers
The High Availability: Fast Failover features work across Layer-3 networks, so there is no need for a direct Layer-2 connection between controllers in a high-availability group
When the AP first connects to its active controller, the active controller provides the IP address of a standby controller, and the AP attempts to establish a tunnel to the standby to the standby controller. If an AP fails to connect to the first standby controller, the active controller will select a new standby controller for that AP, and the AP will attempt to connect to that standby controller.
An AP will failover to its backup controller if it fails to contact its active controller through regular heartbeats and keepalive messages, or if the user manually triggers a failover using the WebUI or CLI.
Configuring High Availability: Fast Failover
Configure the High Availability feature in the WebUI or CLI using the high-availability and high-availability group profiles.
Using the WebUI
To configure High Availability:
 1.Navigate to Configuration>Advanced Services>All Profiles.
 2.In the Profiles list in the left window, expand the HA profile menu.
 3.Select HA group information.
 4.In the HA group information section in the right window pane, enter a name for a new HA group, then click Add.
 5.Select the HA group you just created.
 6.Enter the IP address of each controller in the HA group, and assign a role to each controller. The IP address of each controller must be reachable by APs, and must be the IP address that appears in the Configuration>Controller>System settings tab of the controller WebUI, or in the output of the show controller-ip CLI command.
 Active: Controller is active and is serving APs.
 Dual: Controller serves some APs and acts as a standby controller for other APs.
 Standby: Controller does not serve APs, as only acts as a standby in case of failover.
 7.Select the Allow Preemption checkbox if an AP that has failed over to a standby should attempt to connect back to its original active controller once that controller is reachable again. When you enable this setting, the AP will wait for the time specified by the lms-hold-down-period parameter in the ap system profile before the AP attempts to switch back from the standby controller to the orginal controller.
 8.Click Apply to save your changes.
Using the CLI
Configure the High Availability group:
(host)(config) #ha group-profile <profile>
controller <ip-addr> role active|dual|standby
controller-v6 <ip-addr> role active|dual|standby
preemption
no ...
A controller using the high availability:fast failover feature must be defined as a member of a High Availability group.To add a controller to the new High Availability group, issue following CLI command:
(host)(config)#ha group-membership <ha-group>
Migrating from another Redundancy Solution
ArubaOS has a concept of a local management switch (LMS) and a backup LMS. In a typical deployment, the AP contacts the master mobility controller and is directed to the mobility controller that handles the AP connection and traffic via the LMS parameter. If the LMS becomes unreachable and a backup LMS is specified, the AP attempts to reconnect to that backup mobility controller. This function provides Layer 3 and site redundancy when this level of redundancy is required.
High Availability:Fast Failover provides redundancy for APs, but not for controllers. Deployments that require mastercontroller redundancy should continue to use an existing VRRP redundancy solution.
If your deployment currently uses a backup-LMS or VRRP redundancy solution, use the procedures below to migrate to a High-Availability based solution.
Migrating from VRRP Redundancy
Perform the following steps to migrate from VRRP to High-Availability redundancy:
 1.Remove the VRRP IP address as the LMS IP address of the AP.
(host) (AP system profile) #no lms-ip
 2.Configure the AP to use the active controller’s IP address (not VRRP the IP address) as the LMS-IP for the AP.
(host) (AP system profile) #lms-ip <ipaddress>
 3.Configure the AP to use the standby controller IP address (not VRRP the IP address) as the backup LMS-IP for the AP.
(host) (AP system profile) #bkup-lms-ip <ipaddress>
 4.Configure the master controller with an active role in the high-availability group profile.
(host) (config) #ha group-profile grp1
(host) (HA group information "grp1"): controller <ipaddress> role active
 5.Configure thestandby controller with a standby role in the high-availability group profile.
(host) (HA group information "grp1"): controller <ipaddress> role standby
Migrating from Backup-LMS Redundancy
Perform the following steps to migrate from Backup-LMS to High-Availability redundancy and maintain the existing configuration as defined by the lms-ip and bkup-lms-ip parameters in the AP system profile.
 1.Configure the controller serving the AP with an active role in the the high-availability group profile.
 2.Configure the AP’s standby controller with a standby role in the high-availability group profile.
Please feel free for any further help on this.
Cheers,
Venu Puduchery,
All of this information is in the AOS user guide.
Tim
Tim Cappalli | Aruba Security
4me
Contributor I
Is HA configuration need any license, I am not getting the option in 7030 controller which running AOS 6.4.1.0
No additional license is required. You should see the option under Redundancy.
Tim
OK so if this works as outlined in the UG, how does one go about verifying the HA controllers in Dual mode are working properly?
In Dual HA mode, do you have to configure both controllers seperately as Master controllers?
I must be missing something.....
John
The easiest way to test is to pull the links to one of the controllers.
Also, when you run show ap database, you'll see a standby controller IP.
OK I don't yet have any AP's up and running yet but will try that next.
So how do you control which AP's will be served by which controller?
If you use DNS resolution for aruba-master, which controller do you point DNS to?
The documenation for this seems very lacking.....
The ap system profile LMS-IP tells the AP which controller is its primary
controller
OK so DNS would still point to one of the controllers then the AP system profile tells the AP it's primary controller, correct?
