[HELP] AMP report
Airwave version AMP™ 8.0.9.1
I have some question to use AMP report function
1, How to generate report data per AP
2, if it possible to generata the data every 5 minunte and send them to a FTP server?
Thank you very much in advanced!
Best regards
Rickard Sellstedt - IP-Only AB - www.ip-only.com
Re: [HELP] AMP report
What kind of report do you need?  That will determine what you would do.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Current report I got from AMP is a summary report including all the APs in a cluster, I would like to have a report ONLY for a specific AP.  Please guide.
Thanks.
Hi Selric,
There are two ways you could run reports for a specific AP,
1. Go to AP/devices --> Click on Edit option for the devices list --> Select the AP for which you need to run the report, from device action select the option "run report for selected device"
2. Go to reports --> Definitions --> Add new definition --> select the topic, under report restrictions --> device search filter, provide the specific AP MAC or Name.
Vishnu
Vishnu
If my post helped you, don't forget to give kudos ;)
