HELP | ArubaOS <> PaloAlto (Sending user info to Palo Alto via the PAN profile)
Hi AirHeads,
In the last couple of days im running a short POC in a private hospital in my country
I'm trying to use the PaloAlto integration option in order to send each user-id that been authenticated to the PaloAlto (ArubaOS 6.4.2.8)
i followed each of one of the steps of the SG (Solution guide) http://www.arubanetworks.com/pdf/partners/SG_PaloAltoNetworks.pdf
(There is PAN profile on the AAA PROFILE that users are using via the wired port)
when testing  following syntax:
show pan profile
show pan active-profile
show pan state
show pan statistics
show pan debug
That's everything is connected... but even due ..in the PaloAlto i can see the users but no USER-ID has been sent.
Please advise, What do i missing?
Thanks.
Me
Re: HELP | ArubaOS <> PaloAlto (Sending user info to Palo Alto via the PAN profile)
In the Palo dashboard, are you seeing the controller login?
Tim Cappalli | Aruba Security
Yes, Login msgs and Logout msgs..
Why?
Occasional Contributor I
Hi, we are trying the same, but I can't get my PAN state to show as up? Our instants work perfectly, but our master/local setup not at all.
I am pointing the Aruba pan integration to my MGT interface of the PAN. but no logs at all.
I recken it has something to do with the certificate and you need to use the hostname instead of the ip address. any help would be appreciated.
