HTTPS Multistream Issue
Has anyone seen a tendency for a heavily loaded control to start having problems with SSL multistream sites?  Rebooting the controller seems to allow normal operation.
A 6000 controller running OS ... more than 900 users ... users are NATed to a single IP address.  We were unable to load multistream SSL web pages (actually loaded after minutes of delay).   At the same time a using opening an https: single stream loaded without delay.  And at the same time a non-SSL page loaded without problem
Rebooting the controller put operation back to normal.
Looking for any pointers.
