Hello community,
we´ve a RAP3wn and wie want to set the Uplink to 3g.
Ok, we bought the Huawei e353 USB modem witch is on the supported list.
The RAP comes up as an instant. I goes to Settings, and change the settings to Germany and vodafone, then I restart the RAP.
When the RAP is up again I changed it to an Remote AP.
But the USB Modem doesn´t work, it can´t connect to the controller.
When I put the eth 0 interface to the LAN it works.
But we need the 3g uplink for the remote working...
Must I configure something?
modeswitch?
tty?
