drn
Has anyone had issues connecting surface pro 4 to corp wifi ?
we have a win 10 surface pro 4 that just will not connect to our corp wifi. It connects to our guest fine. We have windows 10 on a lenovo laptop and it connects to the corp wifi fine. Anyone ever come across issues with the surface pro ?
Re: Has anyone had issues connecting surface pro 4 to corp wifi ?
I have had problems with Iphones not connecting and discovered that they are listed in the Blacklist section of the controller.  Once I remove the MAC address from the list it connects fine.
After the Windows update, need to forget the corp SSID and reconfigure it.
