Occasional Contributor I
Having a issue receiving clearpass role to my aruba controller for my web authentication
Hi everyone
I am having an issue with our web authentication. We keep getting the redirected page and not going to the orignal web page even after authenticate successfully on Clearpass. I see that the controller is not receiving the role from clearpass to change the user role. Can anyone help me.
Thanks in advance
Raul
Re: Having a issue receiving clearpass role to my aruba controller for my web authentication
You should follow this doc for the controller setup part:
http://www.arubanetworks.com/wp-content/uploads/amigopod-aos-integration-appnote.pdf
And to configure the Guest portion in Clearpass guest starting reading page 190 on the doc I have attached.
Also you can check this video and start at min : 5:06
http://www.youtube.com/watch?v=JJXyLWtfQRo
Hope this helps....:smileywink:
Thank you
Victor Fabian
Lead Mobility Architect
Raul Bracamontes wrote:
Hi everyone
Thanks in advance
Raul
In the Captive Portal Authentication Profile on the Aruba Controller, you have to make sure that the Default role is the "success" role to be assigned to your guests.  As long a ClearPass policy manager sends back a positive result, all guests will obtain the role "guest" when they authenticate successfully.  You might be going in a circle because this role here is some type of "logon" role, which just puts you back to the logon page.
Colin Joseph
Aruba Customer Engineering
