Having two clusters with OC20
Guys I need to deploy around 10 Office connect aps OC20. Since the max number of iaps is 8 per cluster, I will have to do 2 clusters.
So what are the requirements in terms of VLANS, Virtual control (in this case I will have 2 VCs) and roaming between the clutsers-mobility?
