Frequent Contributor I
Heat Map Image not displaying
Aruba 650 controller (6.1.3.7).  trying to upload a floor diagram and the jpg will not display.  any ideas?
Aruba
Re: Heat Map Image not displaying
Does this same picture show up in Visual RF?  Does it have color to it?  If so, try converting it to B&W.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
the issue winded up being a flash issue on my local machine. tested on another machine and it displayed properly. Thanks!
RR8 wrote:
the issue winded up being a flash issue on my local machine. tested on another machine and the image displayed properly. Thanks!
Ah, flash issue. I did not think of this possibility, Thanks.
