Occasional Contributor I
Hello, I have a platform with a hundred 105 Aps, all manage with a 3600 Controller. A couple of days
Hello, I have a platform with a hundred 105 Aps, all manage with a 3600 Controller. A couple of days ago the 11 an / 11 bgn leds are red steady, the signal quality is very poor in some areas the connection keeps dropping. I check in the controller and it seems to be working through the 2.4 but the 5.0 appears to be setup as well, I didn’t setup this platform in the first place but I think the one who done it had no clue of it. I also realize all the clients are working through the “G” band even those devices that has an N card connection…. Any ideas???
Re: Hello, I have a platform with a hundred 105 Aps, all manage with a 3600 Controller. A couple of
You should definitely open a case with TAC in parallel to this post.  You could have any number of things going on at this time.
Hello
Go to the AP group to the rf managment and check that the High throughput is enabled
Here
Check that on 802.11g and 802.11a profile as well.
Cheers
Carlos
Alternetworks Corp
Also check on the SSID profile you got the HT(Hight Throghput SSID) on as well
Alternetworks Corp
Check as well what the encryption the ssid is using.  If it is set to TKIP then as per the standard, that will only use legacy rates and not the HT rates.
I have seen many instances on deployments put in a long time ago that were setup originally with TKIP and even though they have deployed new AP105s, they are stuck on legacy rates.
But, yes as cjoseph said, you should open a case with TAC if this is a recent occurance.
ACCP, ACCX #817, ACMP, ACMX #294
Thanks a lot buddy, will try this!
Thank you very much Carlos!
