Occasional Contributor I
Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2 as RAP. I can see isakmp and ipsec SAs, I can see RAP "up" in "ap database", but there is flag Rc2ID and there is no connectivity. Does anybody have an idea what to do?
Re: Hello, I have a problem to connect RAP5WN to Aruba 650, Ver. 6.3.1.2.
Type "show log system 50" and see if you can see any errors.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I can see just this
Mar 3 16:47:04 :305056:  <WARN> |stm|  AP 00:0b:86:66:3a:d0 No response from AP for LOG_CONFIG request for 3614 sec; deleting AP.
Mar 7 11:02:28 :325048:  <ERRS> |authmgr|  GSM delete failed for mac-user 00:00:00:00:00:00 with error 'ERROR_HTBL_KEY_NOT_FOUND'
Mar 7 11:22:39 :325048:  <ERRS> |authmgr|  GSM delete failed for mac-user 00:00:00:00:00:00 with error 'ERROR_HTBL_KEY_NOT_FOUND'
Mar 7 11:32:07 :303022:  <WARN> |AP 00:0b:86:66:3a:d0@10.1.1.35 nanny|  Reboot Reason: No reboot message found.
Mar 7 11:32:39 :325048:  <ERRS> |authmgr|  GSM delete failed for mac-user 00:00:00:00:00:00 with error 'ERROR_HTBL_KEY_NOT_FOUND'
Mar 7 12:32:30 :305056:  <WARN> |stm|  AP 00:0b:86:66:3a:d0 No response from AP for LOG_CONFIG request for 3614 sec; deleting AP.
Mar 7 12:58:57 :303022:  <WARN> |AP 00:0b:86:66:3a:d0@10.1.1.39 nanny|  Reboot Reason: No reboot message found.
Mar 7 12:59:09 :325048:  <ERRS> |authmgr|  GSM delete failed for mac-user 00:00:00:00:00:00 with error 'ERROR_HTBL_KEY_NOT_FOUND'
Mar 7 13:59:13 :305056:  <WARN> |stm|  AP 00:0b:86:66:3a:d0 No response from AP for LOG_CONFIG request for 3614 sec; deleti
In the AP-Group that the RAP5WN is in, is there a Virtual AP, or WLAN?
RAP is in ap group rap
There is:
wlan virtual-ap "Demro-vap_prof"
   aaa-profile "Demro-aaa_prof"
   ssid-profile "Demro-ssid_prof"
   vlan 1
wlan virtual-ap "home-1"
   vlan 20
   forward-mode split-tunnel
   rap-operation always
wlan virtual-ap "rap-ap"
   vlan 20
ap provisioning-profile "default"
ap provisioning-profile "rap"
   remote-ap
   master set "demro.dyndns.org"
rf arm-rf-domain-profile
   arm-rf-domain-key "50e56550be5d0d23b64733c33a81e7e8"
ap-group "default"
ap-group "rap"
   virtual-ap "rap-ap"
   enet1-port-profile "NoAuthWiredPort"
   enet2-port-profile "NoAuthWiredPort"
   enet3-port-profile "NoAuthWiredPort"
   enet4-port-profile "NoAuthWiredPort"
   ap-system-profile "rap"
Does VLAN 20 exist on the controller?  Type "show profile-errors"
Invalid Profiles ---------------- Profile                   Error -------                   ----- wlan virtual-ap "home-1"  Error: Remote-AP "always" virtual-ap must have bridge forwarding mode
(aruba-master) #
VLAN 20 is there:
interface vlan 20
        ip address 192.168.20.1 255.255.255.224
        operstate up
(without operstate up it was down)
ip dhcp pool RemClients
 default-router 192.168.20.1
 network 192.168.20.0 255.255.255.224
 authoritative
Is there an LMS-IP in the AP system profile RAP?  If so, please remove it.
I have removed it. But it is the same. After reset of RAP I can see "upgrading", then "rebooting", after reboot it ends up with "up", flag "Rc2ID".
AP Database
Name               Group    AP Type  IP Address    Status              Flags  Switch IP    Standby IP
00:0b:86:66:3a:d0  rap      RAP-5WN  10.1.1.44     Up 6m:34s           Rc2ID  192.168.1.2  0.0.0.0
00:1a:1e:10:15:37  default  93H      192.168.1.95  Up 22d:20h:38m:19s         192.168.1.2  0.0.0.0
00:24:6c:cb:55:a9  default  105      192.168.1.94  Up 22d:20h:37m:56s         192.168.1.2  0.0.0.0
00:24:6c:cc:5b:92  default  93       192.168.1.97  Up 22d:20h:38m:5s          192.168.1.2  0.0.0.0
Maybe I have some bad configuration. Can I find some functional configuration example?
Type "show ap image version" to see what image the RAP has.  This will only work when the RAP is connected to the controller.
Try also changing it to the default ap group and see if it comes up.
