Hello guys, please help me connect huawei e153u-1 to Aruba RAP-3WN
What is i need to type in:
usb type:
usb dev:
usb tty:
usb init:
usb dial:
usb modem switch:
usb auth type:
usb user:
usb password:
Re: Hello guys, please help me connect huawei e153u-1 to Aruba RAP-3WN
I don't see that model on the list of support modems. Check out page 196 of the attached doc.
Tim Cappalli | Aruba Security
You can check the list as well here
http://www.arubanetworks.com/support-services/interoperability/#4g-usb-instant
Cheers
Carlos
Alternetworks Corp
unfortunately my model is not (. Happens when  this model is not listed of support of RAP-3WN, I hav't another methods to connect it?
Super Contributor I
Take note even for supported model, some firmware on the dongle may not work and I had to ask the ISP to flash to a lower firmware to work after I consulted TAC.
Normal Guy
