Help! Clearpass guest login going back to registration page after clicking login. Im new to Aruba
as per tac.You will need to make changes on the controller user-roles, so that the authenticated users can gain access to internet and other network resources. Currently you have created 3 post-authentication roles, but they all contain the ACLs which are usually used to configure a pre-authenticated captive portal based user role.
Unless the changes on these 3 roles are made, authenticated users will not be able to access anything except ClearPass page.
Re: Help! Clearpass guest login going back to registration page after clicking login. Im new to Arub
Please follow these instructions
https://ase.arubanetworks.com/solutions/id/3
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect
He said that i need to create an access list to allow connection going to internet. When i add an acl to permit anythong its still going back to registration page
For the sake of testing, make your post-authentication role the built-in authenticated role and see if everything works.
Sent from Nine<>
Tim Cappalli | Aruba Security
Aruba
Couple of things to check:
Check your post-auth role in your Captive Portal profile; and share with us the following:
show rights <role name>
Also, on CPPM, are you sure you see the authentication hitting a service (in Access Tracker)?    If not, confirm that you have changed your AAA Server Group under the Captive Portal Profile.   This is often missed and defaults to the internal server group; in this case, authentiation would fail and revert to the "initial role" which would bring back the captive portal page.
ACCX | ACDX | ACMX
