Help me, plaese!
I got a problem when using xml-api command "user_query"
The Aruba Controller reply following information:
<aruba>
  <status>Ok</status>
  <code>0</code>
  <macaddr>00:17:c4:f9:xx:xx</macaddr>
  <name>00:17:c4:f9:xx:xx@govwifi</name>
  <role>auth-guest</role>
  <type>Wireless</type>
  <vlan>115</vlan>
  <location>LOC15AP02</location>
  <age>00:00:11</age>
  <auth_status>Unauthenticated</auth_status>
  <essid>aruba</essid>
Anyone can help me? T_T
Re: Help me, plaese!
it replied OK with the user info, what exactly is wrong in your case ?
