Help me!!
Help me, i want to download AOS 6.1.4.0
from where?
Re: Help me!!
Open a TAC case requesting access to 6.1.4.0
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Re: Help me!!
i don't know , how to do TAC requesting
  tell me plz
Re: Help me!!
If you follow the link below you can open a case via email or phone
http://www.arubanetworks.com/support-services/
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Re: Help me!!
Why you want that?
As far i know 6.1.4.0 is not for production network...
Instead of that you could download the .6.2.0 versoin... just check the release note before upgrading.
Alternetworks Corp
Re: Help me!!
I think that the RAP3s are only supported on the 6.1.4 code
Thank you
Victor Fabian
Re: Help me!!
Thats the minimum  release supported to deoploy it as remote AP
If you read the release notes of the 6.2 you will see this
RAP-3WN and RAP-3WNP Remote Access Points
This release of ArubaOS introduces support for RAP-3WN and RAP-3WNP access points (APs). The Aruba
RAP-3WN and RAP-3WNP are single-radio, single-band wireless APs that support the IEEE 802.11n
standard for high-performance WLAN.
Do you have Rap3 that you need to deploy as Remote AP?
Remember to read the release note and the readme file before upgrading to this version... its really important!
Alternetworks Corp
thx you , for Anwser !!
