Contributor I
Help needed: Guest SSID (open) should see Captive Portal - but it doesn't
Hi for customer we have to setup Guest SSID with Captive Portal.
On the Captive Portal, jsut a button should be shown that's says 'Go Online' and link to terms.html.
I have used this manual http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Content/ArubaFrameStyles/Captive_Portal/Captive_Portal_Authentic.htm
Succeeded every step, but now conencting to the SSID, no Captive Portal shows up. I can go to safari on the iPhone and browse the web or use Apps.
What am I missing? We need the Captive Portal and a redirect URL.
Frequent Contributor I
Re: Help needed: Guest SSID (open) should see Captive Portal - but it doesn't
Have similar experience not so long ago.. did you use newest browser? Do you inject certificate on controller for CP?
I solve mine after injecting self-cert on controller. It seems that chrome (not sure about safari) reject and wont display the web content.
Self-cert with open ssl :
http://community.arubanetworks.com//t5/ControllerBasedWLANs/generate-self-signed-certificate-with-openssl/m-p/275357
Try using firefox.
Do you have a public CA-signed certificate on the controller for captive portal?
Tim Cappalli | Aruba Security
