Help only getting 300 mbs Ap115
Hello I have 2 ap 115 setup on vertual controler and when im next to the ap's the max speed I get is 300mbs. I have the 80hz support enabled. But im sure im missing somthing. Can some one point me to what need to be done so I do get speed faster then 300mps?
Re: Help only getting 300 mbs Ap115
Does your client support 80mhz channels?
Yes they do. I had dfrent ap's before setup for wide ch before and they where getting 1200.
By they way here is my config. Mybe I should change somthing? I only have like 10 clients on this 2 ap's i many wanted it for fast roming.
version 6.4.4.0-4.2.4
virtual-controller-country US
virtual-controller-key f7e8927f188f994780da45a0b858a16ae9
name ArubaDown
virtual-controller-ip 192.168.1.8
terminal-access
telnet-server
led-off
clock timezone Eastern-Time -05 00
rf-band all
allowed-ap 18:64:72:cb:e4:77
allowed-ap 18:64:72:cb:e2:84
arm
 wide-bands all
 80mhz-support
 min-tx-power 18
 max-tx-power 127
 band-steering-mode prefer-5ghz
 air-time-fairness-mode fair-access
 client-aware
 scanning
 client-match
rf dot11g-radio-profile
 spectrum-monitor
 dot11h
rf dot11a-radio-profile
 spectrum-monitor
 dot11h
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system
syslog-level warn user
syslog-level warn user-debug
syslog-level warn wireless
extended-ssid
mgmt-user User123 3382fc9c860a8861dfa9127075e8ab02f
wlan access-rule default_wired_port_profile
 index 0
 rule any any match any any any permit
wlan access-rule wired-instant
 index 1
 rule masterip 0.0.0.0 match tcp 80 80 permit
 rule masterip 0.0.0.0 match tcp 4343 4343 permit
 rule any any match udp 67 68 permit
 rule any any match udp 53 53 permit
wlan access-rule AlexN5G
 index 3
wlan ssid-profile AlexN5G
 enable
 index 1
 type employee
 essid AlexN5G
 wpa-passphrase da2fe9e9721dbfdbc67a6
 opmode wpa2-psk-aes
 max-authentication-failures 0
 rf-band all
 captive-portal disable
 dtim-period 1
 broadcast-filter arp
 g-min-tx-rate 12
 a-min-tx-rate 18
 dmo-channel-utilization-threshold 90
 local-probe-req-thresh 0
 max-clients-threshold 64
 dot11r
 dot11k
 dot11v
 strict-svp
auth-survivability cache-time-out 24
url-visibility
wlan external-captive-portal
 server localhost
 port 80
 url "/"
 auth-text "Authenticated"
 auto-whitelist-disable
 https
blacklist-time 3600
auth-failure-blacklist-time 3600
ids
 wireless-containment none
 infrastructure-detection-level high
 client-detection-level high
 infrastructure-protection-level high
 client-protection-level high
wired-port-profile wired-instant
 switchport-mode access
 allowed-vlan all
 native-vlan guest
 no shutdown
 access-rule-name wired-instant
 speed auto
 duplex auto
 no poe
 type guest
 no dot1x
wired-port-profile default_wired_port_profile
 switchport-mode trunk
 allowed-vlan all
 native-vlan 1
 shutdown
 access-rule-name default_wired_port_profile
 speed auto
 duplex full
 no poe
 type employee
 no dot1x
enet0-port-profile default_wired_port_profile
uplink
 preemption
 enforce none
 failover-internet-pkt-lost-cnt 10
 failover-internet-pkt-send-freq 30
 failover-vpn-timeout 180
airgroup
 enable
airgroupservice airplay
 enable
 description AirPlay
airgroupservice airprint
 enable
 description AirPrint
airgroupservice itunes
 enable
airgroupservice remotemgmt
 enable
airgroupservice sharing
 enable
airgroupservice chat
 enable
airgroupservice AmazonTV
 enable
airgroupservice DIAL
 enable
airgroupservice "DLNA Media"
 enable
airgroupservice "DLNA Print"
 enable
airgroupservice allowall
 enable
Tryed posting my config but its not comng up.
Yes the laptop im trying to get over 300mbs dose support more i had it on 1200 with a defrent ap.
name ArubaDown
terminal-access
telnet-server
led-off
rf-band all
allowed-ap 18:64:72:c2:e1:70
allowed-ap 18:64:72:c5:02:84
arm
 wide-bands all
 80mhz-support
 min-tx-power 18
 max-tx-power 127
 client-aware
 scanning
 client-match
 spectrum-monitor
 dot11h
 spectrum-monitor
 dot11h
extended-ssid
 index 0
 index 1
 index 3
 enable
 index 1
 type employee
 essid AlexN5G
 opmode wpa2-psk-aes
 rf-band all
 dtim-period 1
 g-min-tx-rate 12
 a-min-tx-rate 18
 dot11r
 dot11k
 dot11v
 strict-svp
url-visibility
 server localhost
 port 80
 url "/"
 https
blacklist-time 3600
ids
 allowed-vlan all
 native-vlan guest
 no shutdown
 speed auto
 duplex auto
 no poe
 type guest
 no dot1x
 allowed-vlan all
 native-vlan 1
 shutdown
 speed auto
 duplex full
 no poe
 type employee
 no dot1x
uplink
 preemption
 enforce none
airgroup
 enable
 enable
 description AirPlay
 enable
 enable
 enable
 enable
 enable
 enable
 enable
 enable
 enable
 enable
It is possible that your laptop is connecting on the 2.4ghz band.
on the 2.4 the max would be 150mbs no?
Im using my phone now to test its a samsung galaxy s6 edge and im using wifi analyzer it says im connected to ch60(62) 40mhz 270mbps
No.  I would try with a laptop that supports 80mhz channels.
Im thnking it has to do somthing with the adaptive radio managment assigned seting in a ap radio seting as i have all the 5ghz ch avalable in the rf seting under valid chanels. But if i wanted to how would i force 80hz ch?
