Hi, All of my laptops using wifi cannot authenticate with AD and all of it using windows 7
Aruba
Re: Hi, All of my laptops using wifi cannot authenticate with AD and all of it using windows 7
Is this a new problem or are you starting to setup the Aruba?
What is the version of AOS?
What method of authentication, PEAP or TLS?
What does 'show log error 20' and 'show log security 20' just after you try to connect some devices?
What do the logs on the AD server show?
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
