Super Contributor II
Hiding SSID on Instant
Hi guys,
I know there is an option to hide the SSID on IAP, as showed below:
However, this feature is not supported on firmware 6.5.1.0-4.3.1.3:
Although the user guide for this firmware states there is this option, so I can't trust the user guide. I would like to know is this feature is supported on 6.5.2.1, but I want to know this prior to upgrading, since this costs a reboot, and I don't want to upgrade, reboot all the IAPs within my cluster and then find out that it is not supported. Does anyone know is this feature is supported on 6.5.2.1 or a way to know it?
Julián
Re: Hiding SSID on Instant
It's there.
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
Ooops, what a slip!
Thank you!
Julián
Hehe. Sometimes you can't see the wood for the trees...
Cheers
James
