High memory usage on Controller 3200XM
I have controller 3200 model and it has very high memory usage up to 80-90%, it has no access point attached and no user connect
My question is Why it use very high memory?
Spoiler
(NCS-DEMO) #show memory
Memory (Kb): total: 691780, used: 617964, free: 73816
(NCS-DEMO) #show version
ArubaOS (MODEL: Aruba3200), Version 6.4.4.5
Website: http://www.arubanetworks.com
Copyright (c) 2002-2016, Aruba Networks, an HP company.
Compiled on 2016-03-03 at 15:39:12 PST (build 54063) by p4build
ROM: System Bootstrap, Version CPBoot 1.1.4.0 (build 16250)
Built: 2007-09-20 16:14:24
Built by: p4build@re_client_16250
Switch uptime is 81 days 19 hours 42 minutes 37 seconds
Reboot Cause: User reboot (Intent:cause:register 78:86:0)
Supervisor Card
Processor XLR 508 (revision B2) with 1187M bytes of memory.
32K bytes of non-volatile configuration memory.
512M bytes of Supervisor Card System flash (model=CF 512MB).
(NCS-DEMO) #
Re: High memory usage on Controller 3200XM
Hey, I assume this is the 3200XM model as opposed to the 3200? (I'm not sure if 512M bytes of Supervisor Card System flash (model=CF 512MB) is the memory upgrade, to me this may just be a 3200 model and the total memory is less then 1Gb) I believe that you cannot install anything higher then Aruba OS 6.2 if you have a standard 3200 controller.
Are you able to identify how much stress the controller is under and if you are reaching your platform limits? For example how many AP's, how many clients connected, do you have EAP termination enabled etc? Ideally the controller should be loaded to no more than 80% of its total capacity.
Are you able to provide the output of the following:
(Lab620) #show memory debug
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Hi Zalion0
I have many controllers 3200 and are the same, using very high memory but still currently works
controller1: 30 APs memory 90% up
controller2: 16 APs memory 80% up
and i will give you a "show memory debug" on the controller3 that no have APs or clients
###I'm sorry for the reply cannot exceed 30,000 characters
Spoiler
(NCS-DEMO) #show memory debug
memory snapshot: Wed May 3 00:40:34 2017
Memory (Kb): total: 691780, free: 72884
79108 /mswitch/bin/fpapps
37976 /mswitch/bin/cfgm
36972 /mswitch/bin/fpcli
36528 /mswitch/bin/arci-cli-helper
28020 /mswitch/bin/fw_visibility
15052 /mswitch/bin/stm
13244 /mswitch/bin/auth
7784 /mswitch/bin/profmgr
7004 /mswitch/bin/isakmpd
6216 /mswitch/bin/wms -l 5
5452 /mswitch/bin/mdns
4960 /mswitch/bin/l2tpd -D
4840 /mswitch/bin/arm
4148 /mswitch/bin/ucm
3628 /mswitch/bin/snmpd
3420 /mswitch/bin/udbserver
2896 /mswitch/bin/pim
2844 /mswitch/bin/mobileip
2596 /mswitch/bin/ospf
2596 /mswitch/bin/ha_mgr
2560 /mswitch/bin/slb
2532 /mswitch/bin/dds
2464 /mswitch/bin/dbsync
2228 /mswitch/bin/pptpd -f
Querying excessively large apps
arci-cli-helper : 35/60M (cur/typical) 0M over
arm : 4/15M (cur/typical) 0M over
auth : 12/30M (cur/typical) 0M over
cfgm : 37/40M (cur/typical) 0M over
dbsync : 2/ 3M (cur/typical) 0M over
dds : 2/100M (cur/typical) 0M over
Type Num Allocs Size Allocs Peak Allocs Peak Size
default 3 48 3 48
PC Allocs Size
0x2b4a5bc4 1 16
0x2b4a5be8 1 16
default 1637 211334 1644 211480
PC Allocs Size
0x404e4c 1 336
0x413678 1 24860
0x4267d4 5 1380
0x2ac1b128 1 8160
0x2ac1c5a0 2 256
0x2acb1e58 26 1872
0x2acb2238 6 11352
0x2acb341c 1 508
0x2acb45e0 1 4184
0x2ad53ebc 1 3612
0x2ad97ae0 1 64
0x2ad9a010 4 320
0x2ad9a378 1 1168
0x2ad9b0d8 3 204
0x2ad9c280 1 80
0x2ad9c2a4 1 4096
0x2af68f7c 499 15968
0x2af6905c 31 1984
0x2af690b0 31 6748
0x2af6a504 470 15040
0x2af6a560 470 6760
0x2af6cdec 35 420
0x2af6cf78 7 112
0x2affc398 12 240
0x2affc4fc 5 80
0x2affd2b4 2 16
0x2b0cf348 4 160
0x2b0dd2e0 1 4020
0x2b0dd7d8 1 41000
0x2b0dd7f8 1 41000
0x2b0dde58 1 9215
0x2b0e33a4 1 4168
0x2b421d14 5 1880
0x2b44d3d4 1 12
0x2b44ea5c 1 12
0x2b4a5ba0 1 16
0x2b4a5bc4 1 16
total 211382 211528
fpapps : 77/85M (cur/typical) 0M over
fpcli : 36/60M (cur/typical) 0M over
fw_visibility : 27/150M (cur/typical) 0M over
ha_mgr : 2/10M (cur/typical) 0M over
isakmpd : 6/30M (cur/typical) 0M over
l2tpd : 4/10M (cur/typical) 0M over
mdns : 5/30M (cur/typical) 0M over
mobileip : 2/ 4M (cur/typical) 0M over
ospf : 2/ 4M (cur/typical) 0M over
pim : 2/ 5M (cur/typical) 0M over
pptpd : 2/ 5M (cur/typical) 0M over
profmgr : 7/ 8M (cur/typical) 0M over
slb : 2/12M (cur/typical) 0M over
snmpd : 3/10M (cur/typical) 0M over
stm : 14/15M (cur/typical) 0M over
ucm : 4/25M (cur/typical) 0M over
udbserver : 3/ 8M (cur/typical) 0M over
wms : 6/200M (cur/typical) 0M over
Large files under /tmp
/tmp/.var/mysql/userdbv3:-rw-r----- 1 root root 1045700 Mar 22 21:03 devid_cache.ISD
Process Output
%CPU S PID PPID VSZ RSS START CMD
0.0 S 1799 1705 154936 79108 Feb10 fpapps
0.0 S 1800 1799 154936 79108 Feb10 fpapps
0.0 S 1801 1800 154936 79108 Feb10 fpapps
0.0 S 1918 1800 154936 79108 Feb10 fpapps
0.0 S 1972 1800 154936 79108 Feb10 fpapps
0.0 S 1998 1800 154936 79108 Feb10 fpapps
0.0 S 1999 1800 154936 79108 Feb10 fpapps
0.1 S 2000 1800 154936 79108 Feb10 fpapps
0.0 S 2006 1800 154936 79108 Feb10 fpapps
0.0 S 2024 1800 154936 79108 Feb10 fpapps
0.0 S 2025 1800 154936 79108 Feb10 fpapps
0.0 S 2026 1800 154936 79108 Feb10 fpapps
0.0 S 2034 1800 154936 79108 Feb10 fpapps
0.0 S 2035 1800 154936 79108 Feb10 fpapps
0.0 S 2036 1800 154936 79108 Feb10 fpapps
0.0 S 2037 1800 154936 79108 Feb10 fpapps
0.0 S 2038 1800 154936 79108 Feb10 fpapps
0.0 S 2039 1800 154936 79108 Feb10 fpapps
0.0 S 2083 1800 154936 79108 Feb10 fpapps
0.0 S 2084 1800 154936 79108 Feb10 fpapps
0.0 S 2085 1800 154936 79108 Feb10 fpapps
0.0 S 2086 1800 154936 79108 Feb10 fpapps
0.0 S 2087 1800 154936 79108 Feb10 fpapps
0.0 S 2088 1800 154936 79108 Feb10 fpapps
0.0 S 2089 1800 154936 79108 Feb10 fpapps
0.0 S 2090 1800 154936 79108 Feb10 fpapps
0.0 S 2091 1800 154936 79108 Feb10 fpapps
0.0 S 2092 1800 154936 79108 Feb10 fpapps
0.0 S 2093 1800 154936 79108 Feb10 fpapps
0.0 S 2207 1800 154936 79108 Feb10 fpapps
0.0 S 1756 1705 58748 37976 Feb10 cfgm
0.0 S 1748 1705 54856 36972 Feb10 fpcli
0.0 S 32420 1748 54856 36972 Apr25 fpcli
0.0 S 1747 1705 53632 36528 Feb10 arci-cli-helper
0.0 S 1968 1705 69080 28020 Feb10 fw_visibility
0.0 S 2435 1968 69080 28020 Feb10 fw_visibility
0.0 S 2436 2435 69080 28020 Feb10 fw_visibility
0.0 S 2437 2435 69080 28020 Feb10 fw_visibility
0.0 S 2438 2435 69080 28020 Feb10 fw_visibility
0.0 S 2439 2435 69080 28020 Feb10 fw_visibility
0.0 S 2440 2435 69080 28020 Feb10 fw_visibility
0.0 S 2441 2435 69080 28020 Feb10 fw_visibility
0.0 S 2442 2435 69080 28020 Feb10 fw_visibility
0.0 S 2452 2435 69080 28020 Feb10 fw_visibility
0.0 S 1841 1705 71788 15052 Feb10 stm
0.0 S 2344 1841 71788 15052 Feb10 stm
0.0 S 2345 2344 71788 15052 Feb10 stm
0.0 S 2346 2344 71788 15052 Feb10 stm
0.0 S 2347 2344 71788 15052 Feb10 stm
0.0 S 2348 2344 71788 15052 Feb10 stm
0.0 S 2349 2344 71788 15052 Feb10 stm
0.0 S 2350 2344 71788 15052 Feb10 stm
0.0 S 2351 2344 71788 15052 Feb10 stm
0.0 S 2362 2344 71788 15052 Feb10 stm
0.0 S 1804 1705 37172 14560 Feb10 licensemgr
0.0 S 1813 1804 37172 14560 Feb10 licensemgr
0.0 S 1814 1813 37172 14560 Feb10 licensemgr
0.0 S 1815 1813 37172 14560 Feb10 licensemgr
0.0 S 1816 1813 37172 14560 Feb10 licensemgr
0.0 S 1817 1813 37172 14560 Feb10 licensemgr
0.0 S 1840 1705 60360 13244 Feb10 auth
0.0 S 2360 1840 60360 13244 Feb10 auth
0.0 S 2361 2360 60360 13244 Feb10 auth
0.0 S 1790 1760 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 1795 1790 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 1796 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 1798 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 1806 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 1830 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.1 S 1852 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 1882 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 2007 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 2057 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 2062 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 2064 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 2105 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 2206 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 2208 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 2363 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 2423 1795 20928 12368 Feb10 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 30288 1795 20928 12368 Apr24 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 30289 1795 20928 12368 Apr24 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 30290 1795 20928 12368 Apr24 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 30291 1795 20928 12368 Apr24 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 30292 1795 20928 12368 Apr24 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 30311 1795 20928 12368 Apr24 mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
0.0 S 1754 1705 43752 11776 Feb10 gsmmgr
0.0 S 1757 1754 43752 11776 Feb10 gsmmgr
0.0 S 1758 1757 43752 11776 Feb10 gsmmgr
0.0 S 2151 1757 43752 11776 Feb10 gsmmgr
0.0 S 1829 1705 23600 7784 Feb10 profmgr
0.0 S 2445 1943 25796 7412 Feb10 apache/bin/httpd -DFOREGROUND -DSSL
0.0 S 1818 1705 23964 7004 Feb10 isakmpd
0.0 S 1819 1705 32644 6216 Feb10 wms -l 5
0.0 S 1831 1819 32644 6216 Feb10 wms -l 5
0.0 S 1832 1831 32644 6216 Feb10 wms -l 5
0.0 S 1833 1831 32644 6216 Feb10 wms -l 5
0.0 S 1834 1831 32644 6216 Feb10 wms -l 5
0.0 S 1835 1831 32644 6216 Feb10 wms -l 5
0.0 S 2379 1831 32644 6216 Feb10 wms -l 5
0.0 S 2004 1705 42308 5452 Feb10 mdns
0.0 S 2012 2004 42308 5452 Feb10 mdns
0.0 S 2013 2012 42308 5452 Feb10 mdns
0.0 S 2014 2012 42308 5452 Feb10 mdns
0.0 S 2015 2012 42308 5452 Feb10 mdns
0.0 S 2016 2012 42308 5452 Feb10 mdns
0.0 S 2017 2012 42308 5452 Feb10 mdns
0.0 S 2018 2012 42308 5452 Feb10 mdns
0.0 S 2019 2012 42308 5452 Feb10 mdns
0.0 S 2374 2012 42308 5452 Feb10 mdns
0.0 S 1896 1705 29528 5364 Feb10 trapd
0.0 S 2283 1896 29528 5364 Feb10 trapd
0.0 S 2284 2283 29528 5364 Feb10 trapd
0.0 S 2285 2283 29528 5364 Feb10 trapd
0.0 S 2286 2283 29528 5364 Feb10 trapd
0.0 S 2287 2283 29528 5364 Feb10 trapd
0.0 S 1951 1705 15844 4960 Feb10 l2tpd -D
0.0 S 2040 1705 35188 4840 Feb10 arm
0.0 S 2421 2040 35188 4840 Feb10 arm
0.0 S 2422 2421 35188 4840 Feb10 arm
0.0 S 2033 1705 43832 4620 Feb10 extifmgr -w 6 -c 6
0.0 S 2041 2033 43832 4620 Feb10 extifmgr -w 6 -c 6
0.0 S 2042 2041 43832 4620 Feb10 extifmgr -w 6 -c 6
0.0 S 2043 2041 43832 4620 Feb10 extifmgr -w 6 -c 6
0.0 S 2044 2041 43832 4620 Feb10 extifmgr -w 6 -c 6
0.0 S 2045 2041 43832 4620 Feb10 extifmgr -w 6 -c 6
0.0 S 2046 2041 43832 4620 Feb10 extifmgr -w 6 -c 6
0.0 S 2047 2041 43832 4620 Feb10 extifmgr -w 6 -c 6
0.0 S 2048 2041 43832 4620 Feb10 extifmgr -w 6 -c 6
0.0 S 2049 2041 43832 4620 Feb10 extifmgr -w 6 -c 6
0.0 S 2339 2041 43832 4620 Feb10 extifmgr -w 6 -c 6
0.0 S 2059 1705 46172 4148 Feb10 ucm
0.0 S 2410 2059 46172 4148 Feb10 ucm
0.0 S 2411 2410 46172 4148 Feb10 ucm
0.0 S 2412 2410 46172 4148 Feb10 ucm
0.0 S 2413 2410 46172 4148 Feb10 ucm
0.0 S 2414 2410 46172 4148 Feb10 ucm
0.0 S 2415 2410 46172 4148 Feb10 ucm
0.0 S 2416 2410 46172 4148 Feb10 ucm
0.0 S 2417 2410 46172 4148 Feb10 ucm
0.0 S 2418 2410 46172 4148 Feb10 ucm
0.0 S 1858 1705 20628 3812 Feb10 dhcpdwrap
0.0 S 1895 1705 21316 3628 Feb10 snmpd
0.0 S 15432 1858 13112 3468 Mar21 dhcpd -f -lf /tmp/dhcpd.lease eth1 -m nonhosp-mode
0.0 S 15433 15432 13112 3468 Mar21 dhcpd -f -lf /tmp/dhcpd.lease eth1 -m nonhosp-mode
0.0 S 15434 15433 13112 3468 Mar21 dhcpd -f -lf /tmp/dhcpd.lease eth1 -m nonhosp-mode
0.0 S 1848 1705 17212 3420 Feb10 udbserver
0.0 S 1750 1705 16944 3364 Feb10 certmgr
1.0 S 1884 1705 28988 3264 Feb10 hwMon
0.0 S 1885 1884 28988 3264 Feb10 hwMon
0.0 S 1886 1885 28988 3264 Feb10 hwMon
0.0 S 1887 1885 28988 3264 Feb10 hwMon
0.0 S 1888 1885 28988 3264 Feb10 hwMon
0.0 S 1889 1885 28988 3264 Feb10 hwMon
0.0 S 1890 1885 28988 3264 Feb10 hwMon
0.0 S 1891 1885 28988 3264 Feb10 hwMon
0.0 S 1892 1885 28988 3264 Feb10 hwMon
0.0 S 1997 1705 15760 3024 Feb10 spectrum
0.0 S 1794 1705 17260 3020 Feb10 aaa
0.0 S 1803 1705 15940 2896 Feb10 pim
0.0 S 2190 1803 15940 2896 Feb10 pim
0.0 S 2191 2190 15940 2896 Feb10 pim
0.0 S 1881 1705 23896 2844 Feb10 mobileip
1.1 S 14488 1920 12248 2844 00:39 sshd: admin@pts/0
0.0 S 2050 1705 13292 2664 Feb10 actagent
0.0 S 1705 1 10392 2616 Feb10 nanny bin/nanny_list 0
0.0 S 1883 1705 14796 2612 Feb10 phonehome
0.0 S 1971 1705 14252 2596 Feb10 ospf
0.0 S 2058 1705 17148 2596 Feb10 ha_mgr
0.0 S 2375 2058 17148 2596 Feb10 ha_mgr
0.0 S 2376 2375 17148 2596 Feb10 ha_mgr
0.0 S 1859 1705 14956 2564 Feb10 rsyncwrap
0.0 S 1908 1705 14360 2560 Feb10 slb
0.0 S 1985 1705 14532 2544 Feb10 cpsec
0.0 S 2052 1705 31752 2532 Feb10 dds
0.0 S 2187 2052 31752 2532 Feb10 dds
0.0 S 2188 2187 31752 2532 Feb10 dds
0.0 S 2189 2187 31752 2532 Feb10 dds
0.0 S 1926 1705 15192 2484 Feb10 cts
0.0 S 1902 1705 14016 2464 Feb10 dbsync
0.0 S 1916 1705 12332 2432 Feb10 resolvwrap
0.0 S 1976 1705 80752 2400 Feb10 lldpd
0.0 S 2217 1976 80752 2400 Feb10 lldpd
0.0 S 2218 2217 80752 2400 Feb10 lldpd
0.0 S 1749 1705 13288 2396 Feb10 packet_filter
0.0 S 1943 1705 13452 2316 Feb10 httpd_wrap
0.0 S 2053 1705 16064 2272 Feb10 ipstm
0.0 S 2061 1705 22936 2272 Feb10 hcm
0.0 S 2254 2061 22936 2272 Feb10 hcm
0.0 S 2255 2254 22936 2272 Feb10 hcm
0.0 S 2256 2254 22936 2272 Feb10 hcm
0.0 S 2257 2254 22936 2272 Feb10 hcm
0.0 S 2258 2254 22936 2272 Feb10 hcm
0.0 S 2259 2254 22936 2272 Feb10 hcm
0.0 S 2377 2053 16064 2272 Feb10 ipstm
0.0 S 2378 2377 16064 2272 Feb10 ipstm
0.0 S 1920 1705 12112 2264 Feb10 /etc/ssh/sshd -D -f /etc/ssh/sshd_config
0.0 S 1962 1705 13892 2228 Feb10 pptpd -f
0.0 S 1836 1705 14136 2080 Feb10 rfm
0.0 S 1038 1035 9092 2000 Feb10 syslogd -x -r -n -m 0 -f conf/syslog.conf
0.0 S 2051 1705 9804 1964 Feb10 actservice
0.0 S 1978 1705 10132 1952 Feb10 util_proc
0.0 S 1762 1705 11184 1868 Feb10 syslogdwrap
0.0 S 1899 1705 12272 1824 Feb10 ntpwrap
0.0 S 2280 1899 6916 1700 Feb10 ntpd -g -L -I 167.97.15.22
0.0 S 2281 2280 6916 1700 Feb10 ntpd -g -L -I 167.97.15.22
0.0 S 2011 1705 52284 1656 Feb10 iapmgr
0.0 S 1981 1705 6684 1504 Feb10 sbHeartbeat -t 1 -m 40
0.0 S 1938 1705 11208 1436 Feb10 qpdq
0.0 S 1752 1705 6988 1376 Feb10 cryptoPOST
0.0 S 2063 1705 8096 1360 Feb10 cert_dwnld
0.0 S 1869 1705 8636 1352 Feb10 radvdwrap
0.0 S 1755 1705 6928 1196 Feb10 pubsub
0.0 S 1936 1705 8984 1144 Feb10 dbbk periodic-backup 10800
0.0 S 1917 1705 6992 1108 Feb10 resolv_hostname
0.0 S 1751 1705 9676 1104 Feb10 soed
0.0 S 1753 1705 6348 1080 Feb10 sbConsoled 0
0.0 R 14567 14536 3960 1040 00:40 ps --user nobody -N -wo %cpu,state,pid,ppid,vsz,rss,start_time,cmd --sort=-rss
0.0 S 1915 1705 5672 1036 Feb10 /usr/sbin/rngd --no-drng=1 --foreground
0.0 S 1633 1 4852 940 Feb10 /usr/sbin/xinetd
0.0 S 1977 1705 3576 856 Feb10 /usr/sbin/dnsmasq -d -o
0.0 S 2334 1859 2904 780 Feb10 /usr/sbin/rsync --daemon --no-detach
0.0 S 1987 1705 4384 696 Feb10 /bin/sh /usr/sbin/mem_mon -v -t 5
0.0 S 1760 1712 4384 672 Feb10 /bin/sh mysql/bin/safe_mysqld --pid-file=/var/mysql/mysql.pid
0.0 S 1712 1705 4384 656 Feb10 /bin/sh dbstart
5.0 S 14536 14535 4384 652 00:40 /bin/sh /usr/sbin/mem_mon
0.0 S 1035 1 4384 624 Feb10 /bin/sh syslogd_start
0.0 S 1911 1705 4384 604 Feb10 /sbin/klogd -n
2.0 S 14535 1748 4384 592 00:40 sh -c mem_mon
0.0 S 1 0 4384 568 Feb10 init
0.0 S 14568 14536 4448 560 00:40 sed -e s/\/mswitch\/bin\///
0.0 S 14569 14536 4448 556 00:40 sed -e s/\/mswitch\///
0.0 S 1982 1705 2172 492 Feb10 pktTraceLogd 0
0.0 S 880 1 4188 448 Feb10 watchdog enable 0
0.0 S 884 1 4188 448 Feb10 watchdog enable 1
0.0 S 888 1 4188 448 Feb10 watchdog enable 2
0.0 S 14489 14488 2176 400 00:39 -sshwrap
0.0 S 14423 1987 4252 396 00:38 sleep 300
1.0 S 14534 1712 4252 396 00:40 sleep 10
0.0 S 2 1 0 0 Feb10 [migration/0]
0.0 S 3 1 0 0 Feb10 [ksoftirqd/0]
0.0 S 4 1 0 0 Feb10 [migration/1]
0.0 S 5 1 0 0 Feb10 [ksoftirqd/1]
0.0 S 6 1 0 0 Feb10 [migration/2]
0.0 S 7 1 0 0 Feb10 [ksoftirqd/2]
0.0 S 8 1 0 0 Feb10 [events/0]
0.0 S 9 1 0 0 Feb10 [events/1]
0.0 S 10 1 0 0 Feb10 [events/2]
0.0 S 11 1 0 0 Feb10 [khelper]
0.0 S 12 1 0 0 Feb10 [kthread]
0.0 S 19 12 0 0 Feb10 [kblockd/0]
0.0 S 20 12 0 0 Feb10 [kblockd/1]
0.0 S 21 12 0 0 Feb10 [kblockd/2]
0.0 S 68 12 0 0 Feb10 [pdflush]
0.0 S 69 12 0 0 Feb10 [pdflush]
0.0 S 71 12 0 0 Feb10 [aio/0]
0.0 S 72 12 0 0 Feb10 [aio/1]
0.0 S 73 12 0 0 Feb10 [aio/2]
0.0 S 70 1 0 0 Feb10 [kswapd0]
0.0 S 717 12 0 0 Feb10 [sp_packet_bh/0]
0.0 S 718 12 0 0 Feb10 [sp_packet_bh/1]
0.0 S 719 12 0 0 Feb10 [sp_packet_bh/2]
0.0 S 737 1 0 0 Feb10 [mtdblockd]
0.0 S 921 1 0 0 Feb10 [kjournald]
File System Disk Space
Filesystem 1k-blocks Used Available Use% Mounted on
none 307200 6752 300448 2% /tmp
/dev/hda3 402161 118626 262771 31% /flash
Memory Statistics
MemTotal: 691780 kB
MemFree: 73116 kB
Buffers: 11432 kB
Cached: 249608 kB
SwapCached: 0 kB
Active: 427072 kB
Inactive: 128856 kB
HighTotal: 458752 kB
HighFree: 1572 kB
LowTotal: 233028 kB
LowFree: 71544 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 0 kB
Writeback: 0 kB
Mapped: 350732 kB
Slab: 28104 kB
CommitLimit: 345888 kB
Committed_AS: 873704 kB
PageTables: 4876 kB
VmallocTotal: 1015800 kB
VmallocUsed: 156 kB
VmallocChunk: 1015644 kB
Ramfs Size :
185828
File Space Usage
0 /home
0 /.ssh
3404 /etc
21812 /lib
0 /log
147712 /mswitch
0 /dev
12 /root
1660 /sbin
2684 /bin
8544 /usr
0 /mnt
0 /fstmp
185828
Spoiler
Kernel Slab Allocator Statistics
slabinfo - version: 2.1
# name <active_objs> <num_objs> <objsize> <objperslab> <pagesperslab> : tunables <limit> <batchcount> <sharedfactor> : slabdata <active_slabs> <num_slabs> <sharedavail>
ip_fib_alias 41 113 32 113 1 : tunables 120 60 8 : slabdata 1 1 0
ip_fib_hash 41 113 32 113 1 : tunables 120 60 8 : slabdata 1 1 0
rpc_buffers 8 8 2048 2 1 : tunables 24 12 8 : slabdata 4 4 0
rpc_tasks 8 20 192 20 1 : tunables 120 60 8 : slabdata 1 1 0
rpc_inode_cache 0 0 480 8 1 : tunables 54 27 8 : slabdata 0 0 0
xfrm6_tunnel_spi 0 0 64 59 1 : tunables 120 60 8 : slabdata 0 0 0
fib6_nodes 9 113 32 113 1 : tunables 120 60 8 : slabdata 1 1 0
ip6_dst_cache 10 34 224 17 1 : tunables 120 60 8 : slabdata 2 2 0
ndisc_cache 1 24 160 24 1 : tunables 120 60 8 : slabdata 1 1 0
RAWv6 6 6 672 6 1 : tunables 54 27 8 : slabdata 1 1 0
UDPv6 204 204 672 6 1 : tunables 54 27 8 : slabdata 34 34 0
tw_sock_TCPv6 0 0 128 30 1 : tunables 120 60 8 : slabdata 0 0 0
request_sock_TCPv6 0 0 128 30 1 : tunables 120 60 8 : slabdata 0 0 0
TCPv6 12 12 1248 3 1 : tunables 24 12 8 : slabdata 4 4 0
UNIX 378 378 448 9 1 : tunables 54 27 8 : slabdata 42 42 0
tcp_bind_bucket 19 203 16 203 1 : tunables 120 60 8 : slabdata 1 1 0
inet_peer_cache 2 59 64 59 1 : tunables 120 60 8 : slabdata 1 1 0
secpath_cache 0 0 128 30 1 : tunables 120 60 8 : slabdata 0 0 0
xfrm_dst_cache 0 0 288 13 1 : tunables 54 27 8 : slabdata 0 0 0
ip_dst_cache 7 15 256 15 1 : tunables 120 60 8 : slabdata 1 1 0
arp_cache 3 24 160 24 1 : tunables 120 60 8 : slabdata 1 1 0
RAW 7 7 544 7 1 : tunables 54 27 8 : slabdata 1 1 0
UDP 108 112 544 7 1 : tunables 54 27 8 : slabdata 16 16 0
tw_sock_TCP 0 0 96 40 1 : tunables 120 60 8 : slabdata 0 0 0
request_sock_TCP 0 0 64 59 1 : tunables 120 60 8 : slabdata 0 0 0
TCP 20 28 1152 7 2 : tunables 24 12 8 : slabdata 4 4 0
flow_cache 0 0 96 40 1 : tunables 120 60 8 : slabdata 0 0 0
cfq_ioc_pool 0 0 48 78 1 : tunables 120 60 8 : slabdata 0 0 0
cfq_pool 0 0 96 40 1 : tunables 120 60 8 : slabdata 0 0 0
crq_pool 0 0 48 78 1 : tunables 120 60 8 : slabdata 0 0 0
deadline_drq 0 0 56 67 1 : tunables 120 60 8 : slabdata 0 0 0
as_arq 8 59 64 59 1 : tunables 120 60 8 : slabdata 1 1 0
mqueue_inode_cache 1 7 576 7 1 : tunables 54 27 8 : slabdata 1 1 0
nfs_write_data 36 40 480 8 1 : tunables 54 27 8 : slabdata 5 5 0
nfs_read_data 32 36 448 9 1 : tunables 54 27 8 : slabdata 4 4 0
nfs_inode_cache 0 0 672 6 1 : tunables 54 27 8 : slabdata 0 0 0
nfs_page 0 0 64 59 1 : tunables 120 60 8 : slabdata 0 0 0
fat_inode_cache 0 0 440 9 1 : tunables 54 27 8 : slabdata 0 0 0
fat_cache 0 0 20 169 1 : tunables 120 60 8 : slabdata 0 0 0
ext2_inode_cache 0 0 496 8 1 : tunables 54 27 8 : slabdata 0 0 0
journal_handle 0 0 20 169 1 : tunables 120 60 8 : slabdata 0 0 0
journal_head 3 72 52 72 1 : tunables 120 60 8 : slabdata 1 1 0
revoke_table 2 254 12 254 1 : tunables 120 60 8 : slabdata 1 1 0
revoke_record 0 0 16 203 1 : tunables 120 60 8 : slabdata 0 0 0
ext3_inode_cache 519 552 512 8 1 : tunables 54 27 8 : slabdata 69 69 0
dnotify_cache 0 0 20 169 1 : tunables 120 60 8 : slabdata 0 0 0
eventpoll_pwq 0 0 36 101 1 : tunables 120 60 8 : slabdata 0 0 0
eventpoll_epi 0 0 96 40 1 : tunables 120 60 8 : slabdata 0 0 0
inotify_event_cache 0 0 28 127 1 : tunables 120 60 8 : slabdata 0 0 0
inotify_watch_cache 0 0 36 101 1 : tunables 120 60 8 : slabdata 0 0 0
kioctx 0 0 192 20 1 : tunables 120 60 8 : slabdata 0 0 0
kiocb 0 0 128 30 1 : tunables 120 60 8 : slabdata 0 0 0
fasync_cache 0 0 16 203 1 : tunables 120 60 8 : slabdata 0 0 0
shmem_inode_cache 794 816 480 8 1 : tunables 54 27 8 : slabdata 102 102 0
posix_timers_cache 0 0 104 37 1 : tunables 120 60 8 : slabdata 0 0 0
uid_cache 1 59 64 59 1 : tunables 120 60 8 : slabdata 1 1 0
blkdev_ioc 17 127 28 127 1 : tunables 120 60 8 : slabdata 1 1 0
blkdev_queue 18 24 976 4 1 : tunables 54 27 8 : slabdata 6 6 0
blkdev_requests 8 21 184 21 1 : tunables 120 60 8 : slabdata 1 1 0
biovec-(256) 256 256 3072 2 2 : tunables 24 12 8 : slabdata 128 128 0
biovec-128 256 260 1536 5 2 : tunables 24 12 8 : slabdata 52 52 0
biovec-64 256 260 768 5 1 : tunables 54 27 8 : slabdata 52 52 0
biovec-16 256 260 192 20 1 : tunables 120 60 8 : slabdata 13 13 0
biovec-4 256 295 64 59 1 : tunables 120 60 8 : slabdata 5 5 0
biovec-1 256 406 16 203 1 : tunables 120 60 8 : slabdata 2 2 0
bio 256 280 96 40 1 : tunables 120 60 8 : slabdata 7 7 0
sock_inode_cache 918 918 448 9 1 : tunables 54 27 8 : slabdata 102 102 0
skbuff_fclone_cache 7 18 416 9 1 : tunables 54 27 8 : slabdata 1 2 0
skbuff_head_cache 869 1220 192 20 1 : tunables 120 60 8 : slabdata 61 61 0
file_lock_cache 0 0 104 37 1 : tunables 120 60 8 : slabdata 0 0 0
proc_inode_cache 13040 13040 392 10 1 : tunables 54 27 8 : slabdata 1304 1304 0
sigqueue 35 135 144 27 1 : tunables 120 60 8 : slabdata 5 5 0
radix_tree_node 3953 3990 276 14 1 : tunables 54 27 8 : slabdata 285 285 0
bdev_cache 3 7 512 7 1 : tunables 54 27 8 : slabdata 1 1 0
sysfs_dir_cache 3411 3496 40 92 1 : tunables 120 60 8 : slabdata 38 38 0
mnt_cache 18 30 128 30 1 : tunables 120 60 8 : slabdata 1 1 0
inode_cache 3820 3820 376 10 1 : tunables 54 27 8 : slabdata 382 382 0
dentry_cache 19286 19314 132 29 1 : tunables 120 60 8 : slabdata 666 666 0
filp 3624 3624 160 24 1 : tunables 120 60 8 : slabdata 151 151 480
names_cache 16 16 4096 1 1 : tunables 24 12 8 : slabdata 16 16 0
idr_layer_cache 111 116 136 29 1 : tunables 120 60 8 : slabdata 4 4 0
buffer_head 17528 21105 56 67 1 : tunables 120 60 8 : slabdata 315 315 0
mm_struct 133 133 544 7 1 : tunables 54 27 8 : slabdata 19 19 0
vm_area_struct 6864 6864 88 44 1 : tunables 120 60 8 : slabdata 156 156 120
fs_cache 177 177 64 59 1 : tunables 120 60 8 : slabdata 3 3 0
files_cache 135 135 448 9 1 : tunables 54 27 8 : slabdata 15 15 0
signal_cache 340 340 384 10 1 : tunables 54 27 8 : slabdata 34 34 0
sighand_cache 140 140 3104 2 2 : tunables 24 12 8 : slabdata 70 70 0
task_struct 318 318 1328 3 1 : tunables 24 12 8 : slabdata 106 106 0
anon_vma 2552 2639 16 203 1 : tunables 120 60 8 : slabdata 13 13 0
size-131072(DMA) 0 0 131072 1 32 : tunables 8 4 0 : slabdata 0 0 0
size-131072 1 1 131072 1 32 : tunables 8 4 0 : slabdata 1 1 0
size-65536(DMA) 0 0 65536 1 16 : tunables 8 4 0 : slabdata 0 0 0
size-65536 0 0 65536 1 16 : tunables 8 4 0 : slabdata 0 0 0
size-32768(DMA) 0 0 32768 1 8 : tunables 8 4 0 : slabdata 0 0 0
size-32768 5 5 32768 1 8 : tunables 8 4 0 : slabdata 5 5 0
size-16384(DMA) 0 0 16384 1 4 : tunables 8 4 0 : slabdata 0 0 0
size-16384 6 6 16384 1 4 : tunables 8 4 0 : slabdata 6 6 0
size-8192(DMA) 0 0 8192 1 2 : tunables 8 4 0 : slabdata 0 0 0
size-8192 563 567 8192 1 2 : tunables 8 4 0 : slabdata 563 567 0
size-4096(DMA) 0 0 4096 1 1 : tunables 24 12 8 : slabdata 0 0 0
size-4096 729 734 4096 1 1 : tunables 24 12 8 : slabdata 729 734 0
size-2048(DMA) 0 0 2048 2 1 : tunables 24 12 8 : slabdata 0 0 0
size-2048 137 142 2048 2 1 : tunables 24 12 8 : slabdata 70 71 0
size-1024(DMA) 0 0 1024 4 1 : tunables 54 27 8 : slabdata 0 0 0
size-1024 104 104 1024 4 1 : tunables 54 27 8 : slabdata 26 26 0
size-512(DMA) 0 0 512 8 1 : tunables 54 27 8 : slabdata 0 0 0
size-512 591 808 512 8 1 : tunables 54 27 8 : slabdata 101 101 27
size-256(DMA) 0 0 256 15 1 : tunables 120 60 8 : slabdata 0 0 0
size-256 144 180 256 15 1 : tunables 120 60 8 : slabdata 12 12 0
size-192(DMA) 0 0 192 20 1 : tunables 120 60 8 : slabdata 0 0 0
size-192 717 740 192 20 1 : tunables 120 60 8 : slabdata 37 37 0
size-128(DMA) 0 0 128 30 1 : tunables 120 60 8 : slabdata 0 0 0
size-128 932 960 128 30 1 : tunables 120 60 8 : slabdata 32 32 0
size-96(DMA) 0 0 96 40 1 : tunables 120 60 8 : slabdata 0 0 0
size-96 6680 6760 96 40 1 : tunables 120 60 8 : slabdata 169 169 0
size-64(DMA) 0 0 64 59 1 : tunables 120 60 8 : slabdata 0 0 0
size-32(DMA) 0 0 32 113 1 : tunables 120 60 8 : slabdata 0 0 0
size-64 1191 1298 64 59 1 : tunables 120 60 8 : slabdata 22 22 0
size-32 2755 3051 32 113 1 : tunables 120 60 8 : slabdata 27 27 0
kmem_cache 136 136 224 17 1 : tunables 120 60 8 : slabdata 8 8 0
Netstat Information
Proto Recv-Q Send-Q Local Address Foreign Address State
udp 13632 0 :::9235 :::*
Large Files above 750K under /
784 /bin/tcpdump
956 /etc/publicCACerts/ca-bundle.crt
1944 /lib/libarci.so
1292 /lib/libc-2.3.6.so
6044 /lib/libcmdtree.so
1768 /lib/libcmnutil.so
1676 /lib/libcrypto.so.1.0.0
856 /lib/libm-2.3.6.so
804 /lib/libpdf.so
2064 /lib/libregparsing.so
896 /lib/libstdc++.so.6.0.3
2156 /mswitch/apache/bin/httpd
3064 /mswitch/bin/IANA.xml
2344 /mswitch/bin/actwldiff
2344 /mswitch/bin/arci-cli-helper
4728 /mswitch/bin/auth
2472 /mswitch/bin/bocmgr
3628 /mswitch/bin/cfgm
1012 /mswitch/bin/cpboot_nebbiolo
984 /mswitch/bin/dhcpd
3288 /mswitch/bin/extifmgr
5408 /mswitch/bin/fpapps
2344 /mswitch/bin/fpcli
1160 /mswitch/bin/fw_visibility
908 /mswitch/bin/hcm
1212 /mswitch/bin/hwMon
856 /mswitch/bin/iperf
2040 /mswitch/bin/isakmpd
1340 /mswitch/bin/licensemgr
2392 /mswitch/bin/mdns
828 /mswitch/bin/mobileip
780 /mswitch/bin/mon_test
1180 /mswitch/bin/ntpd
1284 /mswitch/bin/profmgr
2956 /mswitch/bin/snmpd
5988 /mswitch/bin/sos.3200.elf
5988 /mswitch/bin/sos.3400.elf
5992 /mswitch/bin/sos.3600.elf
5992 /mswitch/bin/sos.m3.elf
4836 /mswitch/bin/stm
780 /mswitch/bin/syslogd
2152 /mswitch/bin/trapd
1040 /mswitch/bin/ucm
1940 /mswitch/bin/wms
1348 /mswitch/conf/dbupgrade.sql
1392 /mswitch/mysql/libexec/mysqld
828 /mswitch/webui/clilib/oui-list.js
1516 /mswitch/webui/jscripts/monitor/MFramework-single.js
816 /mswitch/webui/jscripts/monitor/data_model.js
5228 /mswitch/webui/jscripts/monitor/deploy/compiler.jar
788 /mswitch/webui/monitoring_xml/page_descr.xml
976 /mswitch/webui/switch/SSHTermApplet-signed.jar
1872 /mswitch/webui/switch/Spectrum.swf
2016 /usr/bin/7za
2392 /usr/sbin/mdns
844 /usr/sbin/rsync
Spoiler
Files in /tmp directory (in blocks)
4 /tmp/.cfgmsync
12 /tmp/.fpcli_cfg_diff
12 /tmp/.fpcli_cfg_diff_enc
4 /tmp/.var/aruba_xlrdebug/hw/dma/credits
4 /tmp/.var/aruba_xlrdebug/hw/dma/ctrlregs
4 /tmp/.var/aruba_xlrdebug/hw/dma/dbgcntrs
4 /tmp/.var/aruba_xlrdebug/hw/gmac0/credits
4 /tmp/.var/aruba_xlrdebug/hw/gmac0/debugregs
4 /tmp/.var/aruba_xlrdebug/hw/gmac0/eventcntrs
4 /tmp/.var/aruba_xlrdebug/hw/security/credits
4 /tmp/.var/aruba_xlrdebug/hw/security/ctrlregs
4 /tmp/.var/aruba_xlrdebug/hw/security/debugregs-rsa
4 /tmp/.var/aruba_xlrdebug/hw/security/debugregs-sec0
8 /tmp/.var/aruba_xlrdebug/net/eth1/info
8 /tmp/.var/aruba_xlrdebug/net/eth1/stats
8 /tmp/.var/aruba_xlrdebug/sw/eth1/info
8 /tmp/.var/aruba_xlrdebug/sw/eth1/stats
140 /tmp/.var/aruba_xlrdebug/sw/sos_console/data
4 /tmp/.var/aruba_xlrdebug/sw/sos_console/info
4 /tmp/.var/aruba_xlrdebug/sw/sos_info/maps
4 /tmp/.var/aruba_xlrdebug/sw/watchdog/irt_stats
4 /tmp/.var/aruba_xlrdebug/sw/watchdog/watchdog_print_dbg
4 /tmp/.var/aruba_xlrdebug/sw/watchdog/watchdog_stats
4 /tmp/.var/aruba_xlrdebug/sw/watchdog/watchdog_timeout
4 /tmp/.var/aruba_xlrdebug/sw/watchdog/watchdog_type
4 /tmp/.var/aruba_xlrdebug/sw/watchdog/wd_jiffies
4 /tmp/.var/log/boot.log
4 /tmp/.var/log/lastlog
52 /tmp/.var/log/local.log
48 /tmp/.var/log/messages
104 /tmp/.var/log/messages.1
104 /tmp/.var/log/messages.2
4 /tmp/.var/log/oslog/AAA.log
4 /tmp/.var/log/oslog/ACTIVATE.log
0 /tmp/.var/log/oslog/AP-DEBUG.log
0 /tmp/.var/log/oslog/APPROC.log
0 /tmp/.var/log/oslog/ARM-USER-DEBUG.log
0 /tmp/.var/log/oslog/ARM.log
0 /tmp/.var/log/oslog/ARMD.log
8 /tmp/.var/log/oslog/AUDITTRAIL-LOGIN_OUT.log
48 /tmp/.var/log/oslog/AUDITTRAIL.log
4 /tmp/.var/log/oslog/AUTHMGR.log
0 /tmp/.var/log/oslog/BLE_RELAY.log
4 /tmp/.var/log/oslog/CERTMGR.log
0 /tmp/.var/log/oslog/CERT_DWNLD.log
4 /tmp/.var/log/oslog/CFGM.log
4 /tmp/.var/log/oslog/CPSEC.log
0 /tmp/.var/log/oslog/CRYPTO.log
4 /tmp/.var/log/oslog/CTS.log
4 /tmp/.var/log/oslog/DBSYNC.log
0 /tmp/.var/log/oslog/DDS.log
4 /tmp/.var/log/oslog/DHCPD.log
4 /tmp/.var/log/oslog/ESI.log
4 /tmp/.var/log/oslog/EXTIFMGR.log
4 /tmp/.var/log/oslog/FPAPPS.log
4 /tmp/.var/log/oslog/FW_VISIBILITY.log
4 /tmp/.var/log/oslog/GSMMGR.log
4 /tmp/.var/log/oslog/HA_MGR.log
4 /tmp/.var/log/oslog/HCM.log
4 /tmp/.var/log/oslog/HTTPD.log
0 /tmp/.var/log/oslog/HWMON.log
4 /tmp/.var/log/oslog/IAPMGR.log
0 /tmp/.var/log/oslog/INTUSER.log
0 /tmp/.var/log/oslog/IPSTM.log
4 /tmp/.var/log/oslog/L2TP.log
4 /tmp/.var/log/oslog/LICENSEMGR.log
4 /tmp/.var/log/oslog/LLDP.log
4 /tmp/.var/log/oslog/LOCALDB.log
4 /tmp/.var/log/oslog/MDNS.log
4 /tmp/.var/log/oslog/MOBILEIP.log
4 /tmp/.var/log/oslog/NETWORK.log
0 /tmp/.var/log/oslog/NPPPD.log
4 /tmp/.var/log/oslog/OSPF.log
4 /tmp/.var/log/oslog/PACKETFILTER.log
4 /tmp/.var/log/oslog/PHONEHOME.log
4 /tmp/.var/log/oslog/PIM.log
0 /tmp/.var/log/oslog/PPPD.log
0 /tmp/.var/log/oslog/PPPOED.log
0 /tmp/.var/log/oslog/PPTP.log
4 /tmp/.var/log/oslog/PROCESSES.log
4 /tmp/.var/log/oslog/PROFMGR.log
0 /tmp/.var/log/oslog/PUBLISHER.log
4 /tmp/.var/log/oslog/RADVD.log
4 /tmp/.var/log/oslog/RESOLVWRAP.log
0 /tmp/.var/log/oslog/RFD.log
0 /tmp/.var/log/oslog/RFM.log
4 /tmp/.var/log/oslog/RSYNC.log
4 /tmp/.var/log/oslog/SAPD.log
64 /tmp/.var/log/oslog/SECURITY.log
104 /tmp/.var/log/oslog/SECURITY.log.1
104 /tmp/.var/log/oslog/SECURITY.log.2
4 /tmp/.var/log/oslog/SNMP.log
0 /tmp/.var/log/oslog/SNMP_AP.log
4 /tmp/.var/log/oslog/SPECTRUM.log
4 /tmp/.var/log/oslog/STM.log
4 /tmp/.var/log/oslog/STM_AP.log
0 /tmp/.var/log/oslog/SUSER.log
4 /tmp/.var/log/oslog/SYSLOGDWRAP.log
56 /tmp/.var/log/oslog/SYSTEM.log
0 /tmp/.var/log/oslog/TRAFFIC.log
4 /tmp/.var/log/oslog/UCM.log
0 /tmp/.var/log/oslog/USER-DEBUG.log
12 /tmp/.var/log/oslog/USER.log
0 /tmp/.var/log/oslog/UTIL-PROC.log
32 /tmp/.var/log/oslog/WIRELESS.log
4 /tmp/.var/log/oslog/WMS.log
4 /tmp/.var/log/oslog/apache_httpd.pid
4 /tmp/.var/log/oslog/dds/dds_error.log
4 /tmp/.var/log/oslog/dds/dds_fd.log
4 /tmp/.var/log/oslog/dds/dds_gsm.log
4 /tmp/.var/log/oslog/dds/dds_main.log
80 /tmp/.var/log/oslog/errors.log
104 /tmp/.var/log/oslog/errors.log.1
104 /tmp/.var/log/oslog/errors.log.2
0 /tmp/.var/log/oslog/gsm/GSM_air_group.trc
0 /tmp/.var/log/oslog/gsm/GSM_arm.trc
0 /tmp/.var/log/oslog/gsm/GSM_auth.trc
0 /tmp/.var/log/oslog/gsm/GSM_dds.trc
0 /tmp/.var/log/oslog/gsm/GSM_dhcpdwrap.trc
0 /tmp/.var/log/oslog/gsm/GSM_extifmgr.trc
0 /tmp/.var/log/oslog/gsm/GSM_fpapps.trc
0 /tmp/.var/log/oslog/gsm/GSM_fw_visibility.trc
320 /tmp/.var/log/oslog/gsm/GSM_gsm_mgr.trc
0 /tmp/.var/log/oslog/gsm/GSM_ha_mgr.trc
0 /tmp/.var/log/oslog/gsm/GSM_hcm.trc
0 /tmp/.var/log/oslog/gsm/GSM_ipstm.trc
0 /tmp/.var/log/oslog/gsm/GSM_lldpd.trc
0 /tmp/.var/log/oslog/gsm/GSM_mip.trc
0 /tmp/.var/log/oslog/gsm/GSM_pim.trc
0 /tmp/.var/log/oslog/gsm/GSM_stm.trc
0 /tmp/.var/log/oslog/gsm/GSM_ucm.trc
0 /tmp/.var/log/oslog/gsm/GSM_wms.trc
92 /tmp/.var/log/oslog/license-log.txt
140 /tmp/.var/log/oslog/license-log.txt.1
388 /tmp/.var/log/oslog/memlogs/mm_logs.tar.gz
4 /tmp/.var/log/oslog/vinfo
8 /tmp/.var/log/trace/stm.log
108 /tmp/.var/log/trace/stm.log.0
108 /tmp/.var/log/trace/stm.log.1
0 /tmp/.var/mysql/agrp_db/policy.ISD
4 /tmp/.var/mysql/agrp_db/policy.ISM
12 /tmp/.var/mysql/agrp_db/policy.frm
4 /tmp/.var/mysql/agrp_db/version.ISD
4 /tmp/.var/mysql/agrp_db/version.ISM
12 /tmp/.var/mysql/agrp_db/version.frm
0 /tmp/.var/mysql/gapdb/auto_prov_id.ISD
4 /tmp/.var/mysql/gapdb/auto_prov_id.ISM
12 /tmp/.var/mysql/gapdb/auto_prov_id.frm
0 /tmp/.var/mysql/gapdb/auto_prov_table.ISD
4 /tmp/.var/mysql/gapdb/auto_prov_table.ISM
12 /tmp/.var/mysql/gapdb/auto_prov_table.frm
48 /tmp/.var/mysql/gapdb/global_ap_table.ISD
184 /tmp/.var/mysql/gapdb/global_ap_table.ISM
12 /tmp/.var/mysql/gapdb/global_ap_table.frm
32 /tmp/.var/mysql/gapdb/global_radio_table.ISD
12 /tmp/.var/mysql/gapdb/global_radio_table.ISM
12 /tmp/.var/mysql/gapdb/global_radio_table.frm
4 /tmp/.var/mysql/gapdb/real_version.ISD
4 /tmp/.var/mysql/gapdb/real_version.ISM
12 /tmp/.var/mysql/gapdb/real_version.frm
4 /tmp/.var/mysql/gapdb/version.ISD
4 /tmp/.var/mysql/gapdb/version.ISM
12 /tmp/.var/mysql/gapdb/version.frm
0 /tmp/.var/mysql/iapdb/global_iap_table.ISD
4 /tmp/.var/mysql/iapdb/global_iap_table.ISM
12 /tmp/.var/mysql/iapdb/global_iap_table.frm
0 /tmp/.var/mysql/iapdb/trusted_branch_table.ISD
4 /tmp/.var/mysql/iapdb/trusted_branch_table.ISM
12 /tmp/.var/mysql/iapdb/trusted_branch_table.frm
4 /tmp/.var/mysql/iapdb/version.ISD
4 /tmp/.var/mysql/iapdb/version.ISM
12 /tmp/.var/mysql/iapdb/version.frm
0 /tmp/.var/mysql/licensedb/licenseinfo.ISD
4 /tmp/.var/mysql/licensedb/licenseinfo.ISM
12 /tmp/.var/mysql/licensedb/licenseinfo.frm
4 /tmp/.var/mysql/licensedb/licenseinfo_new.ISD
4 /tmp/.var/mysql/licensedb/licenseinfo_new.ISM
12 /tmp/.var/mysql/licensedb/licenseinfo_new.frm
4 /tmp/.var/mysql/mysql.err
4 /tmp/.var/mysql/mysql.pid
0 /tmp/.var/mysql/mysql/columns_priv.ISD
4 /tmp/.var/mysql/mysql/columns_priv.ISM
12 /tmp/.var/mysql/mysql/columns_priv.frm
4 /tmp/.var/mysql/mysql/db.ISD
4 /tmp/.var/mysql/mysql/db.ISM
12 /tmp/.var/mysql/mysql/db.frm
0 /tmp/.var/mysql/mysql/func.ISD
4 /tmp/.var/mysql/mysql/func.ISM
12 /tmp/.var/mysql/mysql/func.frm
0 /tmp/.var/mysql/mysql/host.ISD
4 /tmp/.var/mysql/mysql/host.ISM
12 /tmp/.var/mysql/mysql/host.frm
0 /tmp/.var/mysql/mysql/tables_priv.ISD
4 /tmp/.var/mysql/mysql/tables_priv.ISM
12 /tmp/.var/mysql/mysql/tables_priv.frm
4 /tmp/.var/mysql/mysql/user.ISD
4 /tmp/.var/mysql/mysql/user.ISM
12 /tmp/.var/mysql/mysql/user.frm
4 /tmp/.var/mysql/userdbv3/authsurv_global.ISD
4 /tmp/.var/mysql/userdbv3/authsurv_global.ISM
12 /tmp/.var/mysql/userdbv3/authsurv_global.frm
4 /tmp/.var/mysql/userdbv3/boc_db_version.ISD
4 /tmp/.var/mysql/userdbv3/boc_db_version.ISM
12 /tmp/.var/mysql/userdbv3/boc_db_version.frm
0 /tmp/.var/mysql/userdbv3/boc_dhcp_pool.ISD
4 /tmp/.var/mysql/userdbv3/boc_dhcp_pool.ISM
12 /tmp/.var/mysql/userdbv3/boc_dhcp_pool.frm
0 /tmp/.var/mysql/userdbv3/boc_list.ISD
4 /tmp/.var/mysql/userdbv3/boc_list.ISM
12 /tmp/.var/mysql/userdbv3/boc_list.frm
0 /tmp/.var/mysql/userdbv3/boc_master_info.ISD
4 /tmp/.var/mysql/userdbv3/boc_master_info.ISM
12 /tmp/.var/mysql/userdbv3/boc_master_info.frm
0 /tmp/.var/mysql/userdbv3/boc_static_info.ISD
4 /tmp/.var/mysql/userdbv3/boc_static_info.ISM
12 /tmp/.var/mysql/userdbv3/boc_static_info.frm
0 /tmp/.var/mysql/userdbv3/cert_path.ISD
4 /tmp/.var/mysql/userdbv3/cert_path.ISM
12 /tmp/.var/mysql/userdbv3/cert_path.frm
0 /tmp/.var/mysql/userdbv3/client_blacklist.ISD
4 /tmp/.var/mysql/userdbv3/client_blacklist.ISM
12 /tmp/.var/mysql/userdbv3/client_blacklist.frm
4 /tmp/.var/mysql/userdbv3/client_blacklist_version.ISD
4 /tmp/.var/mysql/userdbv3/client_blacklist_version.ISM
12 /tmp/.var/mysql/userdbv3/client_blacklist_version.frm
4 /tmp/.var/mysql/userdbv3/cpsec_local_ctlr_list.ISD
4 /tmp/.var/mysql/userdbv3/cpsec_local_ctlr_list.ISM
12 /tmp/.var/mysql/userdbv3/cpsec_local_ctlr_list.frm
0 /tmp/.var/mysql/userdbv3/cpsec_master_ctlr_list.ISD
4 /tmp/.var/mysql/userdbv3/cpsec_master_ctlr_list.ISM
12 /tmp/.var/mysql/userdbv3/cpsec_master_ctlr_list.frm
4 /tmp/.var/mysql/userdbv3/cpsec_seq.ISD
4 /tmp/.var/mysql/userdbv3/cpsec_seq.ISM
12 /tmp/.var/mysql/userdbv3/cpsec_seq.frm
4 /tmp/.var/mysql/userdbv3/cpsec_virt_clock.ISD
4 /tmp/.var/mysql/userdbv3/cpsec_virt_clock.ISM
12 /tmp/.var/mysql/userdbv3/cpsec_virt_clock.frm
28 /tmp/.var/mysql/userdbv3/cpsec_whitelist.ISD
12 /tmp/.var/mysql/userdbv3/cpsec_whitelist.ISM
12 /tmp/.var/mysql/userdbv3/cpsec_whitelist.frm
1032 /tmp/.var/mysql/userdbv3/devid_cache.ISD
112 /tmp/.var/mysql/userdbv3/devid_cache.ISM
12 /tmp/.var/mysql/userdbv3/devid_cache.frm
4 /tmp/.var/mysql/userdbv3/devid_cache_version.ISD
4 /tmp/.var/mysql/userdbv3/devid_cache_version.ISM
12 /tmp/.var/mysql/userdbv3/devid_cache_version.frm
0 /tmp/.var/mysql/userdbv3/hosp_userinfo.ISD
4 /tmp/.var/mysql/userdbv3/hosp_userinfo.ISM
12 /tmp/.var/mysql/userdbv3/hosp_userinfo.frm
0 /tmp/.var/mysql/userdbv3/http_session_key.ISD
4 /tmp/.var/mysql/userdbv3/http_session_key.ISM
12 /tmp/.var/mysql/userdbv3/http_session_key.frm
0 /tmp/.var/mysql/userdbv3/local_img_switches.ISD
4 /tmp/.var/mysql/userdbv3/local_img_switches.ISM
12 /tmp/.var/mysql/userdbv3/local_img_switches.frm
0 /tmp/.var/mysql/userdbv3/local_img_upgrade.ISD
4 /tmp/.var/mysql/userdbv3/local_img_upgrade.ISM
12 /tmp/.var/mysql/userdbv3/local_img_upgrade.frm
0 /tmp/.var/mysql/userdbv3/radcheck.ISD
4 /tmp/.var/mysql/userdbv3/radcheck.ISM
12 /tmp/.var/mysql/userdbv3/radcheck.frm
0 /tmp/.var/mysql/userdbv3/radreply.ISD
4 /tmp/.var/mysql/userdbv3/radreply.ISM
12 /tmp/.var/mysql/userdbv3/radreply.frm
4 /tmp/.var/mysql/userdbv3/rap_local_ctlr_list.ISD
4 /tmp/.var/mysql/userdbv3/rap_local_ctlr_list.ISM
12 /tmp/.var/mysql/userdbv3/rap_local_ctlr_list.frm
0 /tmp/.var/mysql/userdbv3/rap_master_ctlr_list.ISD
4 /tmp/.var/mysql/userdbv3/rap_master_ctlr_list.ISM
12 /tmp/.var/mysql/userdbv3/rap_master_ctlr_list.frm
0 /tmp/.var/mysql/userdbv3/rap_whitelist.ISD
4 /tmp/.var/mysql/userdbv3/rap_whitelist.ISM
12 /tmp/.var/mysql/userdbv3/rap_whitelist.frm
56 /tmp/.var/mysql/userdbv3/userinfo.ISD
64 /tmp/.var/mysql/userdbv3/userinfo.ISM
12 /tmp/.var/mysql/userdbv3/userinfo.frm
4 /tmp/.var/mysql/wms/access_point_power_level.ISD
4 /tmp/.var/mysql/wms/access_point_power_level.ISM
12 /tmp/.var/mysql/wms/access_point_power_level.frm
0 /tmp/.var/mysql/wms/active_plan.ISD
4 /tmp/.var/mysql/wms/active_plan.ISM
12 /tmp/.var/mysql/wms/active_plan.frm
172 /tmp/.var/mysql/wms/ap_table.ISD
80 /tmp/.var/mysql/wms/ap_table.ISM
12 /tmp/.var/mysql/wms/ap_table.frm
0 /tmp/.var/mysql/wms/area.ISD
4 /tmp/.var/mysql/wms/area.ISM
12 /tmp/.var/mysql/wms/area.frm
0 /tmp/.var/mysql/wms/area_ng.ISD
4 /tmp/.var/mysql/wms/area_ng.ISM
12 /tmp/.var/mysql/wms/area_ng.frm
0 /tmp/.var/mysql/wms/area_xg.ISD
4 /tmp/.var/mysql/wms/area_xg.ISM
12 /tmp/.var/mysql/wms/area_xg.frm
4 /tmp/.var/mysql/wms/aruba_version.ISD
4 /tmp/.var/mysql/wms/aruba_version.ISM
12 /tmp/.var/mysql/wms/aruba_version.frm
0 /tmp/.var/mysql/wms/bldg_ng.ISD
4 /tmp/.var/mysql/wms/bldg_ng.ISM
12 /tmp/.var/mysql/wms/bldg_ng.frm
0 /tmp/.var/mysql/wms/building.ISD
4 /tmp/.var/mysql/wms/building.ISM
12 /tmp/.var/mysql/wms/building.frm
0 /tmp/.var/mysql/wms/building_xg.ISD
4 /tmp/.var/mysql/wms/building_xg.ISM
12 /tmp/.var/mysql/wms/building_xg.frm
4 /tmp/.var/mysql/wms/campus_xg.ISD
4 /tmp/.var/mysql/wms/campus_xg.ISM
12 /tmp/.var/mysql/wms/campus_xg.frm
0 /tmp/.var/mysql/wms/dap_ng.ISD
4 /tmp/.var/mysql/wms/dap_ng.ISM
12 /tmp/.var/mysql/wms/dap_ng.frm
0 /tmp/.var/mysql/wms/dap_xg.ISD
4 /tmp/.var/mysql/wms/dap_xg.ISM
12 /tmp/.var/mysql/wms/dap_xg.frm
124 /tmp/.var/mysql/wms/event_table.ISD
80 /tmp/.var/mysql/wms/event_table.ISM
12 /tmp/.var/mysql/wms/event_table.frm
12 /tmp/.var/mysql/wms/event_type_table.ISD
4 /tmp/.var/mysql/wms/event_type_table.ISM
12 /tmp/.var/mysql/wms/event_type_table.frm
0 /tmp/.var/mysql/wms/floor.ISD
4 /tmp/.var/mysql/wms/floor.ISM
12 /tmp/.var/mysql/wms/floor.frm
0 /tmp/.var/mysql/wms/floor_ng.ISD
4 /tmp/.var/mysql/wms/floor_ng.ISM
12 /tmp/.var/mysql/wms/floor_ng.frm
0 /tmp/.var/mysql/wms/floor_xg.ISD
4 /tmp/.var/mysql/wms/floor_xg.ISM
12 /tmp/.var/mysql/wms/floor_xg.frm
0 /tmp/.var/mysql/wms/global_user_table.ISD
4 /tmp/.var/mysql/wms/global_user_table.ISM
12 /tmp/.var/mysql/wms/global_user_table.frm
4 /tmp/.var/mysql/wms/http_config.ISD
4 /tmp/.var/mysql/wms/http_config.ISM
12 /tmp/.var/mysql/wms/http_config.frm
4 /tmp/.var/mysql/wms/http_session.ISD
4 /tmp/.var/mysql/wms/http_session.ISM
12 /tmp/.var/mysql/wms/http_session.frm
0 /tmp/.var/mysql/wms/plan_info_updated.ISD
4 /tmp/.var/mysql/wms/plan_info_updated.ISM
12 /tmp/.var/mysql/wms/plan_info_updated.frm
0 /tmp/.var/mysql/wms/probe_sta_table.ISD
4 /tmp/.var/mysql/wms/probe_sta_table.ISM
12 /tmp/.var/mysql/wms/probe_sta_table.frm
84 /tmp/.var/mysql/wms/probe_table.ISD
48 /tmp/.var/mysql/wms/probe_table.ISM
12 /tmp/.var/mysql/wms/probe_table.frm
0 /tmp/.var/mysql/wms/rra_calibration.ISD
4 /tmp/.var/mysql/wms/rra_calibration.ISM
12 /tmp/.var/mysql/wms/rra_calibration.frm
0 /tmp/.var/mysql/wms/rra_ha.ISD
4 /tmp/.var/mysql/wms/rra_ha.ISM
12 /tmp/.var/mysql/wms/rra_ha.frm
0 /tmp/.var/mysql/wms/sap_ng.ISD
4 /tmp/.var/mysql/wms/sap_ng.ISM
12 /tmp/.var/mysql/wms/sap_ng.frm
0 /tmp/.var/mysql/wms/sap_xg.ISD
4 /tmp/.var/mysql/wms/sap_xg.ISM
12 /tmp/.var/mysql/wms/sap_xg.frm
16 /tmp/.var/mysql/wms/sta_table.ISD
20 /tmp/.var/mysql/wms/sta_table.ISM
12 /tmp/.var/mysql/wms/sta_table.frm
0 /tmp/.var/mysql/wms/suggested_access_point.ISD
4 /tmp/.var/mysql/wms/suggested_access_point.ISM
12 /tmp/.var/mysql/wms/suggested_access_point.frm
4 /tmp/.var/run/dhcpd.pid
4 /tmp/.var/run/isakmpd.pid
4 /tmp/.var/run/pptpd.pid
4 /tmp/.var/run/rngd.pid
4 /tmp/.var/run/sshd.pid
4 /tmp/.var/run/utmp
0 /tmp/.var/www/index.html
4 /tmp/RebootCause
0 /tmp/aaa_restart
0 /tmp/auth_restart
4 /tmp/authtmpcert
12 /tmp/certmgr/ServerCert/Wildcard-betagro
8 /tmp/certmgr/ServerCert/all
4 /tmp/certmgr/ServerCert/certaruba
8 /tmp/cfgmSnapshot_mstr
4 /tmp/cliWebCfgData.cfg
0 /tmp/config.changed
4 /tmp/countryCode
0 /tmp/cpsec_enabled
4 /tmp/cpu
4 /tmp/dbbk-periodic.pid
0 /tmp/dbupdated
8 /tmp/deviceCertLib.log.debug
4 /tmp/dhcp_vlan
4 /tmp/dhcpd.lease
4 /tmp/dram_ecc_err_cnt
4 /tmp/drive_test.log
4 /tmp/ecdsa.der
4 /tmp/ecdsakey.dat
4 /tmp/ecdsakey.der
8 /tmp/enc_cfgmSnapshot_mstr
4 /tmp/fieldCertTmp/15/KeyandChain
4 /tmp/fieldCertTmp/15/TrustAnchor
4 /tmp/fieldPrivKeys/private.key.15
4 /tmp/fieldPrivKeys/symKey.bin.15
4 /tmp/gapdb_upgrade_log
4 /tmp/grenache_switch_ip
4 /tmp/gsm_mgr.log
4 /tmp/http_log_level
20 /tmp/httpd.conf
4 /tmp/iapdb_upgrade_log
0 /tmp/ike_restart
0 /tmp/integrity_check_out
4 /tmp/invbarf
4 /tmp/lic_cb
4 /tmp/localtime
4 /tmp/log.bin
60 /tmp/mem_mon_last_poll
36 /tmp/mem_mon_once
0 /tmp/nanny/aaa.txt
0 /tmp/nanny/arci-cli-helper.txt
0 /tmp/nanny/arm.txt
0 /tmp/nanny/auth.txt
0 /tmp/nanny/cert_dwnld.txt
0 /tmp/nanny/certmgr.txt
0 /tmp/nanny/cfgm.txt
0 /tmp/nanny/cpsec.txt
0 /tmp/nanny/cryptoPOST.txt
0 /tmp/nanny/cts.txt
0 /tmp/nanny/dbstart.txt
0 /tmp/nanny/dbsync.txt
0 /tmp/nanny/dds.txt
0 /tmp/nanny/dhcpdwrap.txt
0 /tmp/nanny/fpapps.txt
0 /tmp/nanny/fpcli.txt
0 /tmp/nanny/fw_visibility.txt
0 /tmp/nanny/gsmmgr.txt
0 /tmp/nanny/ha_mgr.txt
0 /tmp/nanny/hcm.txt
0 /tmp/nanny/httpd_wrap.txt
0 /tmp/nanny/hwMon.txt
0 /tmp/nanny/iapmgr.txt
0 /tmp/nanny/ipstm.txt
0 /tmp/nanny/isakmpd.txt
0 /tmp/nanny/l2tpd.txt
0 /tmp/nanny/licensemgr.txt
0 /tmp/nanny/lldpd.txt
0 /tmp/nanny/mdns.txt
0 /tmp/nanny/mobileip.txt
0 /tmp/nanny/ntpwrap.txt
0 /tmp/nanny/ospf.txt
0 /tmp/nanny/packet_filter.txt
0 /tmp/nanny/phonehome.txt
0 /tmp/nanny/pim.txt
0 /tmp/nanny/pptpd.txt
0 /tmp/nanny/profmgr.txt
0 /tmp/nanny/pubsub.txt
0 /tmp/nanny/radvdwrap.txt
0 /tmp/nanny/resolv_hostname.txt
0 /tmp/nanny/resolvwrap.txt
0 /tmp/nanny/rsyncwrap.txt
0 /tmp/nanny/sbConsoled.txt
0 /tmp/nanny/sbHeartbeat.txt
0 /tmp/nanny/slb.txt
0 /tmp/nanny/snmpd.txt
0 /tmp/nanny/spectrum.txt
0 /tmp/nanny/stm.txt
0 /tmp/nanny/syslogdwrap.txt
0 /tmp/nanny/trapd.txt
0 /tmp/nanny/ucm.txt
0 /tmp/nanny/udbserver.txt
0 /tmp/nanny/util_proc.txt
0 /tmp/nanny/wms.txt
4 /tmp/papimon_ports
92 /tmp/pretemp.cfg
4 /tmp/profmgr_ids
4 /tmp/profmgr_pid
0 /tmp/radvd.conf
4 /tmp/ramfs_size
4 /tmp/reg_tbl_processed
0 /tmp/sap_dnlded
4 /tmp/serial
4 /tmp/snmpstart
4 /tmp/snmptrapstart
0 /tmp/soedInternalOnly
0 /tmp/stm_restart
4 /tmp/swkey
4 /tmp/tempCertKey/ArubaTrustedCerts.pem
12 /tmp/tempCertKey/generatedSWCertWithKeyAndChain.pem
4 /tmp/tempCertKey/priveKeyGen.pem
4 /tmp/tempCertKey/symmetricKey.bin
92 /tmp/tmp.cfg
4 /tmp/tpmCertPresent
4 /tmp/tpmKeyHandles.bin
0 /tmp/ucm_restart
4 /tmp/uii.cache
92 /tmp/upg.cfg
Memory Usage (Kbytes) of All processes on the system
14560 /mswitch/bin/licensemgr
12368 /mswitch/mysql/libexec/mysqld --basedir=/mswitch/mysql --datadir=/var/mysql --big-tables --pid-file=/var/mysql/mysql.pid
11776 /mswitch/bin/gsmmgr
7412 /mswitch/apache/bin/httpd -DFOREGROUND -DSSL
5364 /mswitch/bin/trapd
4620 /mswitch/bin/extifmgr -w 6 -c 6
3812 /mswitch/bin/dhcpdwrap
3468 /mswitch/bin/dhcpd -f -lf /tmp/dhcpd.lease eth1 -m nonhosp-mode
3364 /mswitch/bin/certmgr
3264 /mswitch/bin/hwMon
3024 /mswitch/bin/spectrum
3020 /mswitch/bin/aaa
2844 sshd: admin@pts/0
2664 /mswitch/bin/actagent
2616 /mswitch/bin/nanny /mswitch/bin/nanny_list 0
2612 /mswitch/bin/phonehome
2564 /mswitch/bin/rsyncwrap
2544 /mswitch/bin/cpsec
2484 /mswitch/bin/cts
2432 /mswitch/bin/resolvwrap
2400 /mswitch/bin/lldpd
2396 /mswitch/bin/packet_filter
2316 /mswitch/bin/httpd_wrap
2272 /mswitch/bin/ipstm
2272 /mswitch/bin/hcm
2264 /etc/ssh/sshd -D -f /etc/ssh/sshd_config
2080 /mswitch/bin/rfm
2000 /mswitch/bin/syslogd -x -r -n -m 0 -f /mswitch/conf/syslog.conf
1964 /mswitch/bin/actservice
1952 /mswitch/bin/util_proc
1868 /mswitch/bin/syslogdwrap
1824 /mswitch/bin/ntpwrap
1700 /mswitch/bin/ntpd -g -L -I 167.97.15.22
1656 /mswitch/bin/iapmgr
1504 /mswitch/bin/sbHeartbeat -t 1 -m 40
1436 /mswitch/bin/qpdq
1376 /mswitch/bin/cryptoPOST
1360 /mswitch/bin/cert_dwnld
1352 /mswitch/bin/radvdwrap
1196 /mswitch/bin/pubsub
1144 /mswitch/bin/dbbk periodic-backup 10800
1108 /mswitch/bin/resolv_hostname
1104 /mswitch/bin/soed
1080 /mswitch/bin/sbConsoled 0
1036 /usr/sbin/rngd --no-drng=1 --foreground
RSZ CMD
940 /usr/sbin/xinetd
916 ps --user nobody -N -wo rsz,cmd
856 /usr/sbin/dnsmasq -d -o
780 /usr/sbin/rsync --daemon --no-detach
696 /bin/sh /usr/sbin/mem_mon -v -t 5
672 /bin/sh /mswitch/mysql/bin/safe_mysqld --pid-file=/var/mysql/mysql.pid
656 /bin/sh /mswitch/bin/dbstart
652 /bin/sh /usr/sbin/mem_mon
624 /bin/sh /mswitch/bin/syslogd_start
604 /sbin/klogd -n
592 sh -c mem_mon
568 init
508 sort -r
492 /mswitch/bin/pktTraceLogd 0
448 /mswitch/bin/watchdog enable 2
448 /mswitch/bin/watchdog enable 1
448 /mswitch/bin/watchdog enable 0
440 uniq
400 -sshwrap
396 sleep 300
396 sleep 10
0 [sp_packet_bh/2]
0 [sp_packet_bh/1]
0 [sp_packet_bh/0]
0 [pdflush]
0 [mtdblockd]
0 [migration/2]
0 [migration/1]
0 [migration/0]
0 [kthread]
0 [kswapd0]
0 [ksoftirqd/2]
0 [ksoftirqd/1]
0 [ksoftirqd/0]
0 [kjournald]
0 [khelper]
0 [kblockd/2]
0 [kblockd/1]
0 [kblockd/0]
0 [events/2]
0 [events/1]
0 [events/0]
0 [aio/2]
0 [aio/1]
0 [aio/0]
(NCS-DEMO) #
