Frequent Contributor I
Historical data for RAP
Is there a way to look at historical data for RAPs? Looking to see if there is a throughput trend with specific RAP usage.
NOTE: Airwave is not deployed in this enviroment, therefore hoping this is something that can be viewed directly from the 3600 WLAN controller.
Tony Marques
Re: Historical data for RAP
There is very little (if any) historical information stored on the controller.
Tim Cappalli | Aruba Security
