Frequent Contributor I
Historical goodput values and 40Mhz Intolerrance
Hi All
Hope I am posting this in the correct board.
I have 2 Questions
1.)  Is there anyway to get a historical view of goodput (as seen on the dashboard) -- clicking it and looking at the trend I only see at most history for the past hour. Is there another way to see goodput values from lets say 2 days ago?
2.) What does 40Mhz Intollerance do and why would I want to enable it or leave disabled on my High-Through-Put radio?
Thanks in advance
Re: Historical goodput values and 40Mhz Intolerrance
1.  The controller does not have much historical information, so two hours is probably the most you will see.
2.  For an explanation, please search for intolerance here:  http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/AP_Config/RF_Management.htm
