How Client Steering be implemented? What technology?
I would like to know how client steering is done by Aruba.
My understanding:
- decision making of roaming from one AP to another is positioned on endpoint device
Question:
- if that is the case, how "Client Steering" can interrupt this methodology to force client to associate to the "best" AP for better connectivity?
- Hence, why not putting "roaming decision" on Wi-Fi system instead of endpoint to prevent sticky client issue?
Thanks.
Re: How Client Steering be implemented? What technology?
Please start with this:
http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Content/ArubaFrameStyles/ARM/Client_Match.htm
