Occasional Contributor I
How I can re-provision an AP 70 without a break out cable?
[ Edited ]
Can anybody tell me how I can re-provision an AP 70 without a break out cable?
Re: How I can re-provision an AP 70 without a break out cable?
The only other possibility is via SPOE. The 2400 and 800 controllers support this method of AP provisioning. You may also be able to find a switch that supports SPOE and plug the AP70 into that and provision.
No worries guys.  I had my E&I guys build me a break out cable from the AP 70 guide.  Works like a champ.
D'oh!  I have a 3400.
