How I unblocked a SSID in the controller?
When I finished the configuration on the controller, and I change a rol in the SSID it´s locked,  I don´t can change the parameters because the legend appear "change for cli", Are you know the commands?
Re: How I unblocked a SSID in the controller?
Screenshot, please.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Community Manager
I think this may be what you are looking for, you mentioned "role". Its configuration>securitty: authentication> profilesaaa.PNG
Airheads Community - The best place to Connect. Engage. and Learn.
