Contributor I
How To Specify SSID and Radio On Aruba 7005 Controller 8.0.1.0
Hello, Sure hope some on can help
I just upgraded by 7005 Controller to OS 8.0.1.0 and I have been struggling for about 8 hours trying to get two AP 225's the way I want them.
I am trying to get two SSID's across both AP's with one SSID broadcasting 2.4 only on one AP
Example: SSID 1 5G ONLY ACROSS BOTH
                SSID 2 5G AND 2.4 BUT ONLY 2.4 ON ONE AP.
I don't see zones like in IAP and Cloud so not sure on this one.
Thank you
Joseph
