Occasional Contributor I
How authentication works in controller ? and how to confirm whether it is using TACAS/RADIUS ?
I see that there are two servers (Radius and Tacacs) in aaa configuration. How to confirm which protocol controller is using for authentication.. In my ACS controllers are registered with one IP address and now ACS logs showing that auth requests are coming from different IPs than what already there in ACS. How to change it ? Appreciate your help. Thanks.
Re: How authentication works in controller ? and how to confirm whether it is using TACAS/RADIUS ?
Look under configuration > administration and see what server group is set for management authentication.
You can also run:
Show aaa authentication-server mgmt
Tim Cappalli | Aruba Security
