How can I filter smart phones from connecting to my WLAN?
  • 1.  How can I filter smart phones from connecting to my WLAN?
    Posted Sep 20, 2013 01:56 PM
    I have 12 schools in all in my school district.  In each school, I have a cluster of 30- 50 IAP-105 with the WLAN doing WPA-Personal security.  Things are working good, except I'm seeing alot of smart phones connecting and I want to be able to control this or block this?  Can anyone please tell me how I can do this with just the IAP cluster?  Are there any filters that I can create?
    Thanks, Maverick
  • 2.  RE: How can I filter smart phones from connecting to my WLAN?
    Posted Sep 20, 2013 03:16 PM
    You can move all the smartphones based on fingerprinting and then move those to a role that denies everything , i have attached a user guide.
    This is currently supported in IAP OS 6.2.1.0-3.4.0.x
    Attachment(s)
  • 3.  RE: How can I filter smart phones from connecting to my WLAN?
    Posted Oct 30, 2013 02:17 PM
    Is there a way to do this and limit them by radio?
    Like if i want all mobile clients to connect only on 2.4ghz, and laptops to connect only on 5ghz, is that possible?
  • 4.  RE: How can I filter smart phones from connecting to my WLAN?
    Posted Oct 30, 2013 05:57 PM
    There is not a way i can think of that you could steer mobile clients to one band with an IAP cluster. You might be able to with CPPM but I would have to dig around on that one but your first post clearly states with a IAP cluster only.
  • 5.  RE: How can I filter smart phones from connecting to my WLAN?
    Posted Jun 25, 2014 08:53 AM
    hi, how did u setup your AP?
    I have almost same problem. I have 10 AP and for guess network works fine but for employee its not accesising internet access.Plus i have to internet providers. and i want gues goes for one provider with full access and employee for another with restricted access.
    Should i change on my router setting? or just on AP
  • 6.  RE: How can I filter smart phones from connecting to my WLAN?
    Posted Jun 25, 2014 10:36 AM
    Latino_geek
    Please start a new thread so we can answer your question without cluttering up this thread.
    Your issue isn't the same nor will it be answered the same.
