How can be 1 Mbps and 2 Mbps disabled in a WLC 7030?
I want to make mi Cells lower by disabling 1 and 2 Mbps rates. I see 2 options "802.11g transmit rates" and "802.11g basic rates", how should I set basic rates in order to permform this action in the recommended way?
Re: How can be 1 Mbps and 2 Mbps disabled in a WLC 7030?
Set your basic rate to 5.5 and remove 1 and 2 from both basic and transmit.
You can get more aggresive and remove even more rates.
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Legacy-802-11b/m-p/119739
Tim Cappalli | Aruba Security
