How can i format my 7030 controller
hi all,
due to memory probleme i need to erase  my flash memory from the cpboot (i can't access to the to CLI Menu),  i found this methode in the knowledge base.
but when  i try it i got the following messaage
Error Message
any one can help me with this issue
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: How can i format my 7030 controller
This should work:
1) boot the controller
2) wait for the first stage of the boot process  to complete (cpxload)
3) interrupt the second stage by pressing enter when prompted
4) enter the format 0:2 command
5) wait a very long time for this to complete.
6) reload the controller and preboot checks will rewrite data to the config partition allowing you to start the config wizard from CLI
If not contact TAC.:)
Cheers
James
Cheers
James
