How can i setup a trunk port between a RAP and an AP135?
Thank you guys.
I have another question how can i setup a trunk port between a RAP and an AP135.
Is that possible ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Re: How can i setup a trunk port between a RAP and an AP135?
How do you want it to work?  An campus access point connected to the wired port of a RAP is not supported...
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
I would like to connect an IAP to a RAP
Thank you
Victor Fabian
