How can we tell if the antennas are fully aligned for wireless point to point bridge setup?
For wireless point to point bridge setup, how can we tell if the antennas (directional or sectoral) are fully aligned?
Is there an integrated LED indicator (for alignment) that displays signal strength on the AP?
Re: How can we tell if the antennas are fully aligned for wireless point to point bridge setup?
Which access point?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Aruba 270 series APs.
It does not have a light.  You will need to run a command to see the RSSI
(Aruba7650-US) #show ap mesh neighbors ap-name Mesh-225
Neighbor list
MAC                Portal             Channel  Age  Hops  Cost  Relation                 Flags  RSSI  Rate Tx/Rx  A-Req  A-Resp  A-Fail  HT-Details     Cluster ID
9c:1c:12:90:59:50  9c:1c:12:90:5d:91  149E     0    1     1.00  C 3d:21h:26m:15s         VLK    26    780/780     2      2       0       VHT-80MHz-3ss  3FEEF727-4ACE-4586-9817
9c:1c:12:90:59:51  9c:1c:12:90:5d:91  149E     0    1     1.00  N 3d:21h:26m:56s         VLK    25    -           0      0       0       VHT-80MHz-3ss  3FEEF727-4ACE-4586-9817
Thanks for the info, Colin.
