Frequent Contributor II
How centralize licensing work?
How centeralized licenseing worklets say I have 20 AP and 2 controllers should I buy only 20 AP LIC and put it on master and it will be a centeralized server for local to license ?
Re: How centralize licensing work?
Correct. The controllers “check out” a license for each AP / feature. (AP license, PEF-NG, RFProtect)
Sent from Windows Mail
Tim Cappalli | Aruba Security
Ok dear tim so now I don't need to spend more money on license for each controller right I buy only license for one controller and ther other validate the access points if it fail over to it am I correct?
Correct.
Thank Victor so thats mean we only need Licenses on Masters only and if I have one Master and 3 locals I will buy only 20 AP lic Part number (AP-LIC-20) only right?
How many APs do you have across all your controllers ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
