Frequent Contributor II
How dd the access point define its controller if we are using Master-Master backup ?
Lets say I have 4 controllers 2 master-master back up and 2 lcoals lets say that in options 43 I typed the VRRP IP now how access point will find the controller if Master fail?
Re: How dd the access point define its controller if we are using Master-Master backup ?
If the option 43 points to the master-vrrp, then the backup master will take over in the event of the master failing.  You shouldn't see any disruption in your setup.
ACCP, ACCX #817, ACMP, ACMX #294
What's dhcp 43 IP address that you are using ?if you added the VIP of the master / standby the master dies the standby should take over Based on the priority you set on the vrrp VIP
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Great I mean if the VRRP was 192.168.1.1 and the Option 43 was pointing to 192.168.1.1 then the master fail the redantdunt master will still be reachable through 192.168.1.1?
Yes, correct.
Sent from my HTC mobile device. Please excuse typos.
SecureData
IT security service provider
______________________________________________________________________
The information contained in this message or any of its attachments may be privileged and confidential and intended for the exclusive use of the intended recipient. If you are not the intended recipient any disclosure, reproduction, distribution or other dissemination or use of this communications is strictly prohibited. The views expressed in this email are those of the individual and not necessarily of SecureData Europe Ltd. Any prices quoted are only valid if followed up by a formal written quote.
SecureData Europe Limited. Registered in England & Wales 04365896. Registered Address: SecureData House, Hermitage Court, Hermitage Lane, Maidstone, Kent, ME16 9NT
