How do I assign static IP addresses for the wireless link to MST200 in gateway mode?
We have two MST200s in gateway mode running OSPF and AWR in a Cisco router and switches environment.  I manually create a default route that points to the wireless link ip address which I believe is created randomly.
Everytime we reboot the MST200s, the wireless link creates different sets of ip addresses therefore making my default route invalid and had to manually adjust it to point to the new ip address.
How do I assign static ip addresses to these wireless interfaces?  Is there another way to accomplish this?
Valued Contributor II
Re: How do I assign static IP addresses for the wireless link to MST200 in gateway mode?
HI,
Yes it is possible. check this, I believe this is what you are looking for.
Please feel free if this don't serve your need.
Cheers,
Venu Puduchery,
