Super Contributor II
How do I clear an alert in Instant?
Hi guys,
I have removed an IAP from my Instant cluster and then an alert has appeared stating this AP is down. Since I am not going to place the AP back in the cluster anymore, how can I clear this alert?
Julián
Re: How do I clear an alert in Instant?
Any ideas?
Julián
Hi everybody,
Has anyone had this problem?
Julián
Julina,
Try clear ap debug log and see if it works, else reboot is the only option for now.
# clear debug ap log
Pavan
If my post addresses your query, give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
Hi Pavan,
Thanks for recommendation, but the command didn't work. And now I cannot reboot the VC because it is in production. I think Aruba should build a new release to solve this issue, because rebooting a VC for clearing an alarm causes discomfort, especially when you have to explain to customer.
Julián
Hi
I understand, I would recommand to file feature request and followup with your Aruba system engineer.
Pavan
Pavan
