How do I enable Clarity using Instant Config via Airwave?
This is going to sound beyond stupid, but here goes.  I'm trying to follow the instructions here so I can get Clarity up and running.  Right off the bat, it says
From the CLI, type:
show mgmt-servers
I'm clearly missing something, or that tutorial is clearly expecting me to know something I don't.  Because upon running that, I get a lovely "-bash: show: command not found".
So, could someone please explain to me how I should be running this?  I can only assume I need to enter some sort of 'config' command mode or something, similar to configuring a managed switch or router.  Could someone please point me in the right direction?
Thanks!
Re: How do I run commands once SSH'd into Airwave?
Those commands are when SSH'ed into the xontroller., not Airwave.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Ahh, that makes a lot more sense, thanks!
Ok, so, can I make these commands work for me at all to enable Clarity in Airwave?  Or do I need to do something entirely different?  Or *can* I even get Clarity working using only Airwave and Virtual Controllers at each physical site?
Right now, everything in Airwave > Clarity shows N/A and no information available.  I can only assume something isn't enabled correctly.
By virtual controller you mean IAP cirtual controller or virtual mobility controller (virtualized version of Aruba Mobility Controller).
For clarity for work, you need to have IAPs on OS code 6.5.
Jibran Aziz
CCIE (RnS / SP / DC) , ACDX , ACCP , ACMP
In your instant or airwave you need to go to services and then enable the clarity options (dns, auth , dhcp , etc)
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Also, if these are instant APs, make sure we are on Airwave version 8.2.3.1, as the clarity feature for instant is supported from 8.2.3.1 version of Airwave.
Vishnu
If my post helped you, don't forget to give kudos ;)
Sorry, IAP (Instant Virtual Controller residing on one of the AP's at each site).
Now, is "OS code" different than firmware?  We have no hardware controllers, only Airwave for management and Instant VC's.
Ah!  Good to know.  I believe Airwave is running 8.2.1.1 in our organization.
Ok, we're now on Airwave 8.2.3.1.  But when I go to Groups > Instant Config, select a Virtual Controller, and choose the Services tree from the Menu tab, I don't see the options you specified Victor.  In fact, I don't see any Clarity options, nor do I see the word 'Clarity' in any of the options for Instant via Airwave.
Firmware for the AP's is 6.4.4.8, which I think is the latest.
Am I missing something in order to get Clarity data showing up?  I see the feature is still in Beta...maybe that's why?
EDIT
Just thought of something else, does the model of AP matter for Clarity support?  Do only certain models support that?
Re: How do I enable Clarity using Instant Config via Airwave?
Local management or via Airwave if you go to services you can enable Clarity
Get Outlook for iOS
Thank you
Victor Fabian
